Old 03-24-2008, 07:35 AM   #1 (permalink)
injection pump leaking please help
ih i need to know what usually leaks on an injection pump. when started first thing especialy in the cold my pump leaks and runs down the back of the engine. has any one ever had this happen before? i also was told at car quest the dealer is the only place to go for parts. if i just want to get some seals is there a place online i can get them?
Ford 1991 F Superduty F 47
7.3L IDI 5 Speed
14500 Gvr 8 ft Dump Body
10 lug dana 80
Central Hydraulics
Under Tailgate Spreader
jeremy067390 is offline
Old 03-24-2008, 02:49 PM   #2 (permalink)
My Photos: (9)
Hello, I've had two leaks on mine, one was from the allen screw that sits in a nut uppermost on the back of the pump, just had to tighten the nut. The other one was from bad orings on the throttle shaft, took the shaft to a local rebuilder who replaced them for $2. (My shaft was also bent, very strange, guess that will initiate premature leaks in the future)
There is also a possibility that leaks could come from the plunger on the lower side on the pump, there is an oring in there too, the big nut there might be replaced. If fuel comes out of the escape hole underneath, the inside main shaft seal is bad, that will require a rebuild, the others can be fixed by yourself, keep environment clean! See my gallery for some pics of my IP when I replaced the throttle shaft orings. Got some more info on that also I can send you.
Do not know about any online IP part dealers, sorry...
First find outh where the leak is; dry off good with a cloth, start up and feel around with your fingers until you get them wet somewhere...
1994 E350 Custom Line 7.3IDI, E4OD, 2WD Limited Slip, 4wheel ABS, K&N air filter, 3rd owner, 130K miles on the clock
ACCN - American Car Club of Norway Member no. 263314
My Photo Gallery
RayHell is offline
