Old 08-18-2007, 11:22 PM   #1 (permalink)
injector line crossthread
I may have crossthreaded the 2nd from front of truck on passenger side line while replacing IP pump. I unscrewed and tried to re connect. Noticed metal shavings so I know I have some damage. If line doesnt seal what usually strips the line or the injector threads. What can be done?
Thnaks remote.
1989 F-250 4x4 C-6 7.3
1991 F-250 4x4 E-4OD 7.3
1989 F-350 4x4 5 speed manuel 7.3 (present project truck)
1989 F-350 4x4 E-4OD 7.3 (4 door) (future project)
John deere 450C Crawler
Ford 6610 4x4 Tractor
Diamond Rio Dump Truck
Chevy Dump Truck
International Semi
remote is offline
Old 08-19-2007, 01:16 AM   #2 (permalink)
Re: injector line crossthread
The flare nut. You are going to need a new one.
Sancho
Sancho is offline
Old 08-19-2007, 01:57 AM   #3 (permalink)
My Photos: (9)
I cross threaded one once on my 6.9, all the way down. I removed the injector and cleaned up the threads with a small triangular file I have for that sort of thing, of course removing the shavings. I replaced the injector and screwed the nut down, no further problem. I think if I did not have a small triangular file I could probably have just brute forced the nut on straight and it would have worked as well.
Birken
Birken Vogt is offline
Old 08-24-2007, 07:25 PM   #4 (permalink)
Does anyone know where to get a new flare nut?
1994 F-350 Crew Cab, 4WD, IDI Turbo, E40D, 240k+ miles.
ScubaMedic is offline
Old 08-24-2007, 09:27 PM   #5 (permalink)
the nut is part of the inj line, it doesn't come off. ur gonna have to get a new line. international dealer, a good diesel engine shop, or a donor engine. new ones about 25 or 30 bucks.
88blackidi is offline
Old 08-24-2007, 10:15 PM   #6 (permalink)
suv7734's Avatar
or here as well. Most members who have dealt with these guys have been happy.
Bruce
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
suv7734 is offline
Old 08-28-2007, 08:13 PM   #7 (permalink)
What I am looking for is not the injector line. It is what the injector line connects to on the injector pump side. There is a black fitting that the line connects to.
MWFI does not list it on the site.
Old 08-28-2007, 11:27 PM   #8 (permalink)
arthurgoboom's Avatar
That piece usually stays with the injection pump, if you're referring to the line fitting that is on the distributor section of the IP. The only place I'd know to get one is if you had an old pump you could scavenge one from.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 08-29-2007, 12:41 AM   #9 (permalink)
INJECTOR PUMP SHOP CAN GET THE FITTING IN THE PUMP HEAD.
Diesel Mechanic 28 yrs
Garbage_Mechanic is online now
Old 09-08-2007, 11:05 PM   #10 (permalink)
Just to update this for future searchers. MWFI does carry the part. It's part number 20727. It's not on the web site so you have to call and order it.
You torque it to 60 ft/lbs.
Old 09-09-2007, 12:26 AM   #11 (permalink)
That sounds like way too much torque for such a small thread. Are you sure its 60 ft lbs??
icanfixall is offline
Old 02-08-2008, 05:48 PM   #12 (permalink)
That's what the guy at MWFI told me and that is what was on the little paper that comes with it. I have not seen anything official from Ford on it though.
