Old 07-24-2008, 02:39 PM   #1 (permalink)
injector pump question
Hello, I'm new to the forum, but have looked up answers to a great number of questions in the past now now I need a specific answer, I have a 91 f250 2w 7.3L that wont start, one day I went to goto work and it would not start, this has happened many time to me in the past and has resulted in new GPs, GP relay,fuel filters,8 new injectors and return line kit, each time she ran like a champ alas she has sat for too long and now its time to get her cranked up again... Heres what I know so far(in addition to the above parts being in working order) I have copious(about 2-3 ounces in 5 seconds of cranking) amounts of fuels at the Injector pump inlet, and no fuel at the injectors, am I due for an injector pump or is there something else I should test first? Thank you in advance Mark Taylor
rfb343 is offline
Old 07-24-2008, 05:01 PM   #2 (permalink)
M.L.S.C.'s Avatar
IIRC you're supposed to be seeing at least 1 pint of fuel for 10 seconds of cranking, so at 3 ounces per 5 seconds you're like 10 ounces short of that - I didn't see a lift pump in your list of replaced parts, and since that's what delivers the fuel to the injection pump that would be my prime suspect too.
The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat regular cab long bed, dually, 4.10s, factory tow package w/ P3 controller, single 2.5" stack, wood stakes & rails
M.L.S.C. is offline
Old 07-24-2008, 08:27 PM   #3 (permalink)
That is correct I have not replaced the lift pump, as I thought It was putting out enough fuel, I will double check the pump output for the above volumes and repost the results, thank you.
rfb343 is offline
Old 07-24-2008, 08:37 PM   #4 (permalink)
danngreen's Avatar
Thought it was 1/3 pint in 10 seconds, which is 2-3 ounces in 5 seconds, so you should be getting good fuel delivery at least TO the injector. That's about what mine delivers (I just replaced the caps on the injectors and return lines). I got the 1/3 pint in 10 seconds figure from these posts: 1988 7.3 Navistar Camper, cold start issues Start then no start? cranks but won't start
My first project truck: '90 F250 7.3L IDI 2WD, camper shell, primed and ready to pick color(s). Dual exhaust pipes (stainless) L-O-U-D (gotta get mufflers). Rest is stock, AFAIK
WORK DONE: replaced starter, new return lines/injector-caps, new glow plugs/wiring harness/controller-relay, replaced fuel filter
IN PROGRESS: SVO conversion (installing parts)
danngreen is offline
Old 07-24-2008, 11:34 PM   #5 (permalink)
M.L.S.C.'s Avatar
I stand corrected, guess I missed that "/3" part, lol - never really had to mess with mine, dunno how much fuel it delivers but judging by how strong the truck pulls even bouncing off the governor tis apparently more than enough fuel
M.L.S.C. is offline
Old 07-25-2008, 01:00 AM   #6 (permalink)
arthurgoboom's Avatar
You may want to test the fuel shutoff solenoid to ensure it's working. Turn the key on and go out and disconnect both wires going to the top of the injection pump. There should be an audible click when you touch the connectors to their respective spade terminals. One is the shutoff solenoid, one is the cold advance solenoid. I don't remember which is which but they both should work.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows inside dual to clear springs). 6.9 w/ approx 112,000mi (maybe 212k?). PO mods: Banks non-wastegated turbo system, Rebuilt IP (unknown how many miles). My mods: re-fabricated the Y-pipe, new glowplugs (Beru ZD1A), new Delphi BB injectors, new return lines, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in stock locations inside dash. 3" Mandrel-bent open exhaust. Compression checked @ 400-450 psi. C6 trans (disassembled/cleaned valve body), 3.54 gears. New brakes & brake lines all around. Okiegringo idler pulley. Flushed/recharged/converted A/C to R134a.
arthurgoboom is offline
Old 07-25-2008, 01:55 AM   #7 (permalink)
M.L.S.C.'s Avatar
the FSS runs off the plug closer to the injection pump gear cover
M.L.S.C. is offline
Old 07-25-2008, 07:42 AM   #8 (permalink)
Thanks for clearin up the fuel volume, it seemed to me that it was pump an adequate amount of fuel, I havent had a chance to check the solenoids yet, but I'll check 'em today
rfb343 is offline
Old 07-25-2008, 08:20 AM   #9 (permalink)
My Photos: (27)
Yea, it's something like that as I remember. I was thinking the pint/minute was a mile off. I don't have time to look it up in my shop manual. Bad part is, you feed some poor guy the wrong advice and he wastes time and money replacing the wrong components.
'91 F-250 SC 4X4, 5spd. ATS Turbo My Photos
http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 07-25-2008, 12:48 PM   #10 (permalink)
M.L.S.C.'s Avatar
Oh yeah, that's why I always indicate if I know something for sure,like, if I've personally measured it, or taken it apart - anything else gets the IIRC and AFAIK and similar expressions to go with the info, as that's be something I haven't personally verified, like that fuel flowrate thing now.
M.L.S.C. is offline
Old 07-25-2008, 04:24 PM   #11 (permalink)
Ok, so I know I've got plenty of fuel getting to the IP, and after recharging batteries have found that the when the two wires on the top of the IP are removed and the ignition on, the one towards the front clicks on and off with removing and replacing the wire, the one in the rear does nothing. Now the the other question is what is the grey plastic module on the side of the IP with a 3 wire plug on the drivers side of the IP? thanks
Mark
rfb343 is offline
Old 07-25-2008, 05:19 PM   #12 (permalink)
If you have an automatic that is probably your MPLS. I senses your trottle position and controls the shifting of the transmission.
94 F350 7.3 IDI factory turbo quad cab 4X4 auto North San Diego, Ca
DAVID94IDIT is offline
Old 07-25-2008, 06:08 PM   #13 (permalink)
ok, so Im assuming here that the my cold advance solenoid is bad(as the r and r of the wire to the terminal in the rear did nothing) unless im mistaken and have the FSS and cold advance mixed up, in either case what is involved in replacing them, as I cant find anything bout it online or in either of the Haynes books i got.
rfb343 is offline
Old 07-28-2008, 05:17 PM   #14 (permalink)
M.L.S.C.'s Avatar
Let's start simple - run a jumper wire from a battery's positive terminal (either battery works) to the FSS spade connector (the one closer to the injection pump gear housing), that should take care of any electrical issues you may have and assure that the FSS is open - now try to fire up the engine, whether it fires up or not should help you rule out possible wiring mismatch.
The 3-wire module on the side of the IP is indeed the FIPL, tis like a TPS but only for the E4OD transmission.
M.L.S.C. is offline
