Injector Return line kit - Diesel Forum - TheDieselStop.com
post #1 of 67 (permalink) Old 07-28-2012, 12:45 AM Thread Starter
JASTECH's Avatar
My Photos: (16)
I have the "early" system that uses smaller diameter hose for injectors return line. Would it behoove me to change to "later" system which is larger hose? If so then how? If changed will the connection from hose to metal line behind intake be the only issue? TIA
1988 F350 7.3L Diesel Crew Cab 5spd, 200k+ miles
1980's F250 Cab w/doors, Dash, New Pw/Brk Booster,
sanded and primered Grey [B]For Sale BO
1973 International Scout II
Chevy 350 30over, 4-Bolt main, SS Valves, MSD Ignition, Comp 9000 Dist, Edelbrock Manifold/
Carb,
4" Suspension & 3" Body Lift, Dana Front/Rear/TC, TH400 w/Stage 2 kit, 33x12.5x15 BigO Mud tires.
1973 Jeep CJ5 (Project)
JASTECH is offline
post #2 of 67 (permalink) Old 07-28-2012, 10:07 AM
drinkypoo's Avatar
My Photos: (25)
You should be able to change, it is not supposed to affect anything in your application, yes that should be the only issue, your local auto parts store should have a fitting or fittings for you in brass, but maybe you can get that piece from a 7.3 instead.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #3 of 67 (permalink) Old 07-28-2012, 01:05 PM Thread Starter
JASTECH's Avatar
My Photos: (16)
drinky, Thanks. Ok so is there enough fuel line for the filter to the IP? I will order the kit from ebay w/o injectors as not enough ebay credit. Unless I order via Amazon which I may do. Should I go ahead and replace injectors as they are original but don't know if any are bad? Will it mess up the O-rings to pull everything again later to replace injectors? I need to be schooled on injector options too, will install turbo later but will need power now for the move later on. Any special tools needed? I do have a Mac Injection Pressure tester so will check it to rule out low pressure causing the problems.
Thanks, JASTECH & Son
Carb,
JASTECH is offline
post #4 of 67 (permalink) Old 07-28-2012, 01:27 PM
drinkypoo's Avatar
My Photos: (25)
I'm not sure, how long is that line? My last dipaco kit had a bit of extra hose.
post #5 of 67 (permalink) Old 07-28-2012, 01:28 PM
chuckster57's Avatar
Which Mac set do you have. It takes a special set-up to test the injectors. You have to pressurize them and record the pressure that they "pop" and spray fuel, and that is over 1500 PSI.
I would concentrate on the return system at this point. You can replace the injectors down the line if you have to and replace just the O rings if the caps and lines are still intact. mcmaster carr sells a bag of 50 for less than $7.00
P/N 9464K24 (111)
McMaster-Carr
Train Horns:
PM please not visitor message
chuckster57 is offline
post #6 of 67 (permalink) Old 07-28-2012, 03:41 PM Thread Starter
JASTECH's Avatar
My Photos: (16)
Chuck, dinky, Thanks! Chuck, I was going to test the pressure after the filter on the schrader valve. I read it's suppose to be 6psi? I think the fuel filter was good when you looked at it and poured Seafoam in it Chuck? I would have to buy one with the terminal on the bottom correct?
Carb,
JASTECH is offline
post #7 of 67 (permalink) Old 07-28-2012, 03:52 PM
kobaltblue's Avatar
I bought all my injectors and return lines from the Diesel shop work great good price and support the forum...I buy nothing from epay!
1978 F-150 2 wheel drive 7.3IDI E4OD
kobaltblue is offline
post #8 of 67 (permalink) Old 07-28-2012, 04:50 PM
drinkypoo's Avatar
My Photos: (25)
Remove shrader core, run a line into a jar, 1/3 pint after 10 seconds. put the pressure gauge on, 4-6 psi after 10 seconds. (of fast cranking)
You definitely want the filter with the port on the bottom for your water in fuel sender
post #9 of 67 (permalink) Old 07-28-2012, 06:36 PM Thread Starter
JASTECH's Avatar
My Photos: (16)
dinky, I can't even undo it w/my hands, use oil filter wrench on them? I would like to have one w/clear bowl so I can see when it needs done instead of idiot light I think. How to drain water in them?
Carb,
JASTECH is offline
post #10 of 67 (permalink) Old 07-28-2012, 06:58 PM
The schrader valve Drinky is talking about is in the filter header and looks like a tire inflation valve. I havent seen any filters with a clear bowl for our application.
If the sensor and the wiring are okay, then I wouldn't worry about water until the light came on. We did over 8500 miles and fueled up from a lot of different stations in a lot of different states without any issues. trick is to fill from stations that move high volumes, in our case truck stops.
Train Horns:
post #11 of 67 (permalink) Old 07-28-2012, 07:05 PM
My Photos: (27)
For sure, top quality Dipaco brand you can trust, great prices, quick shipping. They're the internet sales outlet for Midwest Fuel Injection www.thedieselstore.com
LMJD is offline
post #12 of 67 (permalink) Old 07-28-2012, 07:38 PM Thread Starter
JASTECH's Avatar
My Photos: (16)
LMJD, Longtime no see! Thanks for link, but I can't find the return line kit and looking alot. I may not be able to see everything via my smart phone or just can't read, lol
Carb,
JASTECH is offline
post #13 of 67 (permalink) Old 07-28-2012, 07:42 PM
Try this
DPE69120 Injector Installation Kit for 1983 - 1987 Ford 6.9L & 1988 - 1989 Ford 7.3L IDI Diesel Trucks
Train Horns:
post #14 of 67 (permalink) Old 07-28-2012, 08:13 PM
My Photos: (27)
You're welcome. There ya go, Chuckster found it. The 6.9 kits will be the smaller 3/16" hose and 3/16" nipples on the caps and the 7.3 kits take the larger 1/4" hose and 1/4" caps.
LMJD is offline
post #15 of 67 (permalink) Old 07-28-2012, 08:42 PM Thread Starter
JASTECH's Avatar
My Photos: (16)
I don't have the cash to spend, so credit via Ebay or Amazon is what's left. My other half took care of the cards :-(
Carb,
JASTECH is offline
