Re: injectors
tocold4u2,
There's two "O" rings on each.
If the hose between the injectors is grey replace them before they start leaking, also replace the fuel line from filter to the injectors, and the piece going from the injectors to the return line. this will help prevent air from getting sucked in or fuel draining back to the tank.
Get a return line kit form Ford or IH - about $35.00 US, might be able to get a kit cheaper online. It has the hose, new caps, o-rings, and I think it comes with new clips and perhaps copper washers for the injectors but you don’t have to pull the injectors unless they need servicing.
Also, if you can get a hold of a small tube of Molykote 55 O-ring Lubricant made by Dow Corning – I think it’s about $13.00 on line. Use it on the O-rings before slipping them on the injector’s, also wipe a little inside the plastic cap before pushing that on. Good stuff - Slightly swells o-ring, compatible with plastics, operating temperature between – 65c (-85f) and + 165c (+329f). Should keep the o-rings from drying out and or sticking to the injector / plastic areas for a while. That way when you’re working on the engine a year or two from now and bump the lines around may be they wont start leaking again…
93
