Re: injectors
Wow crossbones, you know more about injectors than I thought of asking. They are so cheap that I always replace them (with DPS stage 1 this last time)
dunebrner, The injectors are cheap, go new. And get the return line kit and you will be good to go. Make sure you get the copper washer out of the hole when the old one comes out. And a little anti-sieze on the threads when installing the new ones.
Good luck.
Doug
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
