Injectors starting to go? - Diesel Forum - TheDieselStop.com
Old 11-21-2009, 10:42 AM   #1 (permalink)
Cjhstang's Avatar
What are some good signs that my injectors (and or ip) are starting to go?
Truck is getting a little harder to start again but all aspects of starting system are new. gp's, starter, all cables and terminals, batteries. Spins plenty fast.
It likes to choke a little when its fired up and doesn't like to fire instantly like she used to.
was wonderin if maybe injection related was not vaporizing the fuel or something
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
Old 11-21-2009, 07:33 PM   #2 (permalink)
Snotzalot's Avatar
It's getting colder, which may give you your symptoms.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 11-21-2009, 07:56 PM   #3 (permalink)
Supporting Member
vlamica's Avatar
My Photos: (19)
Not to highjack your thread, but i have the same issue. New glow plugs.. new pump.. new injectors.. correct timing. When the outside temp is 60F or above it fires right up with a nice high idle.. when below that temp it chokes out some black smoke and runs rough for a few seconds until it blows out all the fuel. Plugged into the block heater at any temp perfect. I start thinking about compression.
Vinnie
1994 F-350 7.3 IDIT, Dually crew
C6, Gear Vendors Over/under drive unit
Roll along package, Alcoa wheels
2001 Airstream 30' S/O 70th Anniversary
Air-safe hitch coupled to a Reese Dual Cam
vlamica is offline
Old 11-21-2009, 11:03 PM   #4 (permalink)
Cjhstang's Avatar
Yeah i expected that... but last winter i had the same starting system (cept old gp's) and it started like a hot summer day. (tx to the gear reduction starter) It didn't used to choke around at all. Thats why i was figuring maybe i have a injector here or there that is going out... then once it warms up it works fine...
-3" Body Lift
-8ft snow plow
Cjhstang is offline
