Installed new battery cables from custom cables - Diesel Forum - TheDieselStop.com
Old 03-02-2008, 08:52 PM   #1 (permalink)
pck
I thought it was time to change out my battery cables, as they were almost 20 years old, i've had the truck since '96.
I went the custom battery cable route... and they worked out well. I had to,on drivers side to make a wiring mod as the old ground cable to the battery had two small wires molded into the connector, then the other end went to two sorts of quick-disconnect plugs(no idea,disappeared into wiring harness)
The passenger side battery, the ground to the engine also had a #8 or so wire to the frame, couldn't loosen the bolt(hard to get at) so drilled another hole and attached the ground to it.
Had the same sort of condition with a small wire molded onto the ground terminal, went to gnd. on starter solenoid. Put a #10 in it's place.
All in all, not a bad job......it evened started up!!
Thanks to all who posted about custom battery cables, worked for me!
1989 F-350,5sp,100k,7.3,Had it since 1996,Hypermax Tubo,31/2"exhaust,pyro/boost gauge,cowl induction done 5/07
pck is offline
Old 03-02-2008, 10:42 PM   #2 (permalink)
dakotajeep's Avatar
Good to hear. Mine should be coming this week!!!
Thad
2003 F350 6.0 Lariat Crewcab 4x4 SRW 285/75 16's Treadwright Retread MTG's
Sold:
1994 F350 XL Crewcab 4x4 SRW 7.3 Banks Turbo
Dana 60 Sterling 10.25 3.55, ISSPRO EV Guage and Pyro
PICS of my rigs and random stuff: http://s230.photobucket.com/albums/ee67/dakotajeep/
dakotajeep is offline
Old 03-03-2008, 02:48 PM   #3 (permalink)
Ya... same here too!
I ordered a set saturday...
I did alotta research on trying to find the materials at the lowest cost and was going to do it myself.
Custom battery cables were still cheaper by about $10 or so...
So thats a no brainer 4 me + when you buy all three cables you get free shipping...
1987 F-350 Wrecker 17' Aluminum rollback
7.3L Idi non-turbo (1990)
mattinthebox is offline
Old 04-08-2008, 09:12 PM   #4 (permalink)
where did you get your battery cables and or what are other options. i see the cable coming out of the passenger side positive terminal is cracked and corroded.
-99 early, 09/98, 7.3 f350 lariat crew cab long box dually 4x4, gauges, ais w/fender foam and zoodad, 2 inch level kit, hellwig 1.5" front swaybar, velvet ride shackles, walker btm, gauges, 6.0 intercooler, 6.0 tranny cooler, pmt3, superchips 1705- hey it was free, adrenaline pump, bilsteins, sinnister's hutch mod, 220k
-03 6.0 f350 lariat crew cab long box 4X4: SOLD
-90 xlt lariat crew cab long box 4X4, 7.3: SOLD
-87 turbo t we4 w/ astro roof
-05 chevy uplander-momma's pos
zpd307 is offline
Old 04-08-2008, 10:59 PM   #5 (permalink)
Heavy Duty, Aftermarket, Custom Battery Cables for your Car, Truck or RV
I got mine for $114 delivered (one year ago), great quality. Also, I didn't realize how fried my old cables were until they were removed. Corroded, split, black, bad news.
--Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
Old 04-09-2008, 12:42 AM   #6 (permalink)
i did some more checking and found that site. unfortunately, they seem to be on a hiatus for a couple of more weeks. i tried to look up what they cost, but it would not allow me to. are you still happy with those cables, and were they good to deal with.
zpd307 is offline
Old 04-09-2008, 10:55 AM   #7 (permalink)
dakotajeep's Avatar
I am VERY happy with mine. Its worth the wait unless you need them asap....
Thad
Sold:
Old 04-09-2008, 02:32 PM   #8 (permalink)
i wish i could see their work and prices. i clicked on the f250/f350 link on their site to see, and poof, no go. from what i see of the positive cable, i dont know how one could have one custom made. i looked at a couple of sites and did not see and clamps and such that would work,well. but i do not need them asap, as it does start now and it is only getting warmer.
zpd307 is offline
Old 04-09-2008, 05:33 PM   #9 (permalink)
FraserScott's Avatar
My Photos: (17)
I got mine from O'reilly's auto parts chain down in Minnesota for $75. They are made in the USA and are exceptional quality. The same ones are listed on ebay for $65 under "Northern Auto Parts"....(or something like that).
1990 F-350 XLT Lariat CrewCab 4X4, 7.3L NA IDI, E40D, 3.55, Rebuilt injection pump and injectors, Manually controlled TC, Fleetguard DC4A, 277,000 Kms, Two tone brown. Completely stock. 9200# GVWR. ***In the works of being converted to a ZF-5 with Luk Clutch/ Single mass flywheel conversion***
1986 F-250 supercab 4X2, 6.9l, T-19B 4spd, 3.55LS,8800# GVWR 200,000 kms.
1983 F-250 supercab 4X2, 4.9l, T-18 4spd, 4.10, dad bought it new, dark teal metalic, 317,000 Kms drivetrain all original. 8800# GVWR.
2005 E-150 XL, 7 passenger, 4.6l v8, 3.55 LS, Navy Blue. 44,000 kms.
FraserScott is offline
Old 04-09-2008, 05:38 PM   #10 (permalink)
My Photos: (17)
Acutally, I just checked and they have gone up to $89.99 on ebay.
Old 04-09-2008, 07:20 PM   #11 (permalink)
ill check it out, thanks.
zpd307 is offline
