Installing a Turbo, I need some in put please! - Diesel Forum - TheDieselStop.com
Old 10-23-2005, 10:21 PM   #1 (permalink)
I have a 7.3 in a 1991 IHC school bus. The motor is non turbo and other than color and a couple minor details, appears to be identical to that put in the early 90's Ford pickups. I recently acquired a rebuilt stock turbo off of a 8.2 liter Detriot Diesel, an engine often found in Chevy and Ford buses. Its a non waste-gated Schwitzer turbo and I was wanting to install it on my bus with the 7.3 in it. I'm going to be regearing the bus for highway use and wanted a little bit more power for taking off to supplement the loss from the gearing change. I had a few questions first and wondered what some of you might think.
1. Can I route the turbo directly from the compressor to the intake where the breather sits now? Or do I need to modify the intake so that the air gets forced into the right places? I have been told conflicting stories from different people and wanted another opinion.
2. Is the fact that this turbo is not waste-gated going to be a problem, the engine will constantly be under load (bus weighs 17,500lbs) and running between 2500 and 3000 rpm. The last thing I want to do is risk blowing up the motor, towing a bus isn't cheap by any means.
Any input to these questions is greatly appreciated.
Phillip Johnson
Laidlaw751 is offline
Old 10-23-2005, 11:34 PM   #2 (permalink)
Re: Installing a Turbo, I need some in put please!
Pumping the air into the stock intake (via an intake hat in place of the breather)is how all the commonly available turbo kits do it so you'll have no problem there.
As for it being non wastegated. As long as it doesn't produce more than 12 lbs of boost you'll be alright.
Keith
2000 F350 Cab/Chassis CrewCab 4x4 DRW 7.3/auto "Hamilton Custom Cruiser Conversion" WesternHauler Bed 50gal TFI transfer tank 4" turbo back Exh. DIY intake w/Napa 6637
'88 F350 CrewCab SRW 4x4 7.3/C6/4.10LS Banks non-wastegated turbo NAPA 6637 airfilter 4" lift Airlift rear airbags 107k miles
'89 F350 CrewCab DRW 7.3/E4OD/4.10 124k miles
'86 F250 ext cab. 4x4 6.9/C6/3.55 arrowcraft dually conversion 45gal aft tank ?53k miles
'85 F350 Cab/Chassis DRW 55" Schwalbe Sleeper 7.3/T-19, 4.10, Banks Sidewinder wastegated Turbo Holley red tweaked inj.pump 6.2 governor and STACKS! The old 6.9 gave up after 445k miles.Stacked before stacks were cool since 5/85 **SOLD**
My Pics
'86 F350 Crewcab Dually 6.9/C-6/4.10 LS Racor seperator. 233k miles **SOLD**
'89 F350 Crewcab SRW 4x4 7.3/zf5/4.10LS 193k miles**SOLD**
85Hauler is offline
Old 10-23-2005, 11:46 PM   #3 (permalink)
JPR
You may find it handy to download the installation manual from Banks as a reference for your installation.
Sidewinder turbo manual
Jon
1991 F350 4x4 Crew Cab, original E4OD, 4.10LS, Banks turbo, 3.5" exhaust, 160amp alternator, 285/70R17 tires & wheels.
JPR is offline
Old 10-25-2005, 08:46 AM   #4 (permalink)
My Photos: (23)
Welcome to the site. The bracketry, plumbing, and turbo sizing are what makes the 3 available kits worthwhile. Consider selling the turbo on ebay, and using the money to buy a Hypermax turbo kit (lowest cost, best for hiway).
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, Moose Mister Injectors, Hypermax Turbo, Intercooler, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
