the left side of the instrument panel on my '92 f350 is dark. Is there an easy way to replace the bulb in the instrument cluster?
Can it be done from under the dash, or does the cluster need to be removed?
Any tips?
Thanks----------Robert
'92 F-350 7.3 5 spd, Crew Cab dually,ATS turbo, 4" Exhaust, Air seat, Western Hauler bed. My Gallery
the left side of the instrument panel on my '92 f350 is dark. <font color="red">A.</font> Is there an easy way to replace the bulb in the instrument cluster?
<font color="red">B.</font> Can it be done from under the dash, or <font color="red">C.</font> does the cluster need to be removed?
<font color="red">D.</font> Any tips?
<font color="red">A.</font> NO
<font color="red">B.</font> NO
<font color="red">C.</font> YES
<font color="red">D.</font> Got BEER?
[img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieGringo
You could also try some different bulbs. Try the #168 bulbs. They are brighter than the #194 bulbs that came in the truck. They work in the older dashes. I'm sure they are the same bulbs in '87 and newer as well.
Heath
__________________ 1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
Does the requisit beer consumption begin before pulling the dash, or after ? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Well, that depends on whether you're "A Cheap Date" [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. I drink soo seldom that it only takes 3 beers until I can't be held responsible for what my hands do or what comes outta my mouth [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]. [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieGringo
The biggest problem is the plastic gets brittle so you have to be careful removing the dash when unpluging the fuel selector switch and the wait to start light cluster don't forget the screws under the little trim pieces and you don't remove the cover to the gauges if you look there are 2 sets of screws around the instrument cluster just remove the ones that hold the cluster to the dash [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
I have a 93 dually and I replaced all of the bulbs in the instrument cluster about a year ago. Just be patient, take your time, have it in a warm location so the plastic won't be as brittle. I replaced all of my bulbs while I was in there. I think there are about 18. They are cheap so buy 25 just in case. Change them all while you have it apart so you don't have to do it again for another 14 years! [img]/ubbthreads/images/graemlins/blush.gif[/img]
1993 F350 Dually XLT, Extended cab, red w/running boards, visor, custom hand painted pinstripping, rhino liner, 4.10 rearend, E4OD Tranny, 7.3 liter NA w/K&N, soon to add Banks Turbo, 2nd owner 88K miles, Banks Turbo now added, w/Trans Command...Totally Cool!!!
