Old 01-22-2008, 07:20 PM   #1 (permalink)
Intake question?
Is the 7.3 IDI (1990) inake the same as a (1986) 6.9??????
71swinger400 is offline
Old 01-22-2008, 07:26 PM   #2 (permalink)
Powerstrokedogg's Avatar
Send a message via ICQ to Powerstrokedogg
it should be,
some of the early 6.9s if i remember correctly don't have the soup bowl for the air cleaner but they did have a goofy looking base that worked the same as the soup bowl
as for the intake manifold, they are all the same
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
Powerstrokedogg is offline
Old 01-22-2008, 07:38 PM   #3 (permalink)
Appreciate it. I just want to ensure That I can use my 6.9 intake on the 7.3 if I go that way. I wonder how much difference there is between the 7.3 cam and the 6.9 cam??
Old 01-22-2008, 07:54 PM   #4 (permalink)
cams same also--even turbo--
94_turbo is offline
Old 01-22-2008, 10:03 PM   #5 (permalink)
FraserScott's Avatar
My Photos: (17)
I would have to think you'd need to drill and tap a pair of holes to mount your GP controller. I'm not too sure, but check it out.
1990 F-350 XLT Lariat CrewCab 4X4, 7.3L NA IDI, E40D, 3.55, Rebuilt injection pump and injectors, Manually controlled TC, Fleetguard DC4A, 277,000 Kms, Two tone brown. Completely stock. 9200# GVWR. ***In the works of being converted to a ZF-5 with Luk Clutch/ Single mass flywheel conversion***
1986 F-250 supercab 4X2, 6.9l, T-19B 4spd, 3.55LS,8800# GVWR 200,000 kms.
1983 F-250 supercab 4X2, 4.9l, T-18 4spd, 4.10, dad bought it new, dark teal metalic, 317,000 Kms drivetrain all original. 8800# GVWR.
2005 E-150 XL, 7 passenger, 4.6l v8, 3.55 LS, Navy Blue. 44,000 kms.
FraserScott is offline
Old 01-23-2008, 10:33 AM   #6 (permalink)
mm
the bridge where the newer controller would mounts is taller and uneven on a 6.9. I made an offset wedge to mount the left ear of newer controller .
1992 F250, 5 speed, extended cab, replaced 7.3 with 6.9 2-5-08
DewEze round bale carrier
mm is offline
Old 01-23-2008, 07:58 PM   #7 (permalink)
My truck is an 86 6.9. It is missing on one cylinder. I have not checked it out yet but came across a 1990 7.3 idi non-turbo at a junk yard for 100.00. This yard has low prices and things go quick. Someone had already grabbed the injector pump and all the injectors. I took the long block assy. I figured 100.00 was a fair price. I have pulled one head off the 7.3 and all looks good there so far. I think I may go thru it and drop it in. I know I'll need a set of glow plugs but I think I can make the rest work. I bought a pyrometer the other day. Word is I can crank the fuel up on the 6.9 pump to work with the 7.3.
Old 01-24-2008, 08:45 AM   #8 (permalink)
ltaylor's Avatar
if you have the extra money go through the cylinder heads. the 7.3's are notorious for wearing valve guides quickly.
2001 Excursion Limited, 4x4, toreador red, 4" turbo back exhaust, DYI Tymar intake
92 F350 CC SRW,7.3 E4OD 4x4
4" lift 35" tires, 4.10, 4" exhaust straight pipe,
ATS nwg turbo, rebuilt and balanced, holley red, new IP & injectors, rebuilt heads by me
A pillar triple pod, auto meter phantom gauges,
pyrometer, boost, trans temp, oil pressure & water temp
future upgrades
formerly known as; pullmyfinger
http://community.webshots.com/user/pullmyfinger76
ltaylor is offline
Old 01-24-2008, 11:01 AM   #9 (permalink)
Bill1013's Avatar
If you have an engine stand, mount the engine on it. With 1 head off, block all the water passages you can on the side with the head on, tip the engine on it's side and fill it as full of water as you can, with 2 cyl's at BDC, let it stand for a couple hrs. and check for any moisture at all in those cyl's., rotate for the other two and repeat. I did drivers side 1st on mine, thats how I found my cavitation in #6 . Do the same for the pass side. Save the old head gasket for replacement of head on drivers side. This may save you a lot of trouble if the engine has cavitation. Not a sure way to find cavatation, but it's a chance.
Leave the rad hose on standing up when you fill the drivers side.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Strictly stock. Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB 2WD Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors -New Beru GP's 07/07 New radiator & hoses New WP
Dual Exhaust 3"X18" resonators frnt. of rear wheels
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
Similar Threads
intake question??? JDrescher Power Strokes 1994-1997 Upgrades and Aftermarket 9 09-23-2007 11:19 PM
Intake question insanity 7.3L IDI Diesels (Not Power Strokes) 2 04-11-2007 03:00 AM
intake question ryhed Upgrades and Aftermarket - 7.3L Engine 3 05-18-2006 09:35 PM
Intake question stroken96 Power Strokes 1994-1997 Upgrades and Aftermarket 14 12-07-2005 10:39 AM
INTAKE QUESTION FAZZ1225 Upgrades and Aftermarket - 7.3L Engine 3 09-25-2005 01:02 AM
