Old 06-24-2007, 03:21 AM   #1 (permalink)
Intro and Some Questions
Hello all,
My name is Josh and I live in Oregon. I'm new to this site and have a couple questions.
I've recently purchased a '92 Ford F350 Crew Cab. It is a diesel with a Banks Sidewinder turbo setup and automatic transmission. It has 175,000 mi and is a great runner. It has a trans temp and pyrometer gauges on the pillar. I've recently performed a maintenance including fuel filter, oil change/filter, also replaced all return fuel lines, and O-rings.
Shortly after I bought the truck, the tachometer stopped working. I checked the fuse, as well as checked all wiring and cannot see any obvious problems. Any idea what I should check next to troubleshoot the tach? Also, what is an acceptable operating temperature for the transmission? I am seeing 180^ pulling a heavy load.
This is my first Ford diesel and I'm a newb. [img]/ubbthreads/images/graemlins/smirk.gif[/img] Any help is appreciated.
Thanks in advance.
92Crew
1992 Ford F350 XLT CC
Banks SideWinder, Pyro and Trans Temp Gauges
mach5 is offline
Old 06-24-2007, 03:22 AM   #2 (permalink)
Re: Intro and Some Questions
I have the same problem with my tach, it sucks and my fuel gauge skips around all day.
1993 F-250 5-speed 4x4 7.3L Non-turbo Silver/White Standard cab longbed, American Raching 16.5" wheels, brush guard,Loud duals.
fordguy09 is offline
Old 06-24-2007, 03:52 AM   #3 (permalink)
Bill1013's Avatar
Check the wires on the tach sensor next to the oil fill cap, mine are bare and just about ready to break. The tranny temp can be as high as 250F* for a short while, if you are only running 180F* your tranny temp is prolly only about 20F* higher, 220F* is normal.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo Radio SD & Tape 126,700 03/08 Strictly stock. Build date 03/99
Rebuilding engine. 92 F350 7.3 IDI CC LB 2WD Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
Reman IP - New Delphi Injectors -New Beru GP's 07/07 New radiator & hoses New WP
Dual Exhaust 3"X18" resonators frnt. of rear wheels
Soup bowl gone, 4" intake W/AZ filter
Cobra CB W/Weather Interrupt - Dual Trucker Antenna's
Blk. Grill W/Brush Guards - Fog lights - Rally driving Lights. GN 20K & Reese 16K 5er hitch
http://community.webshots.com/user/oldbull8?
Formally OLDBULL
Toys: 1984 Coachmen Leprechaun F350 Chassis 460CID 92K miles.
30 ft. Jayco Jay Designer 5th wheel.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One flash and it's gone.
Bill1013 is offline
Old 06-24-2007, 04:08 AM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Fordguy.....your fuel guage would most likely be a bad sender in the tank if not a bad wire connection.
A dead tach sender should/would send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Check the wires where they exit the big nut on the oil filler housing , known to short out due to bare wire.....
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too.
You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
Proud Canadian BOOB man too!!
cdnsarguy is offline
