IP for cold weather? - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 01-27-2013, 10:03 PM Thread Starter
Are there IPs out there that are better for cold weather. I had a shop tell me the pumps they use are designed for the cold and winter blend fuel that we have up here in ak. Makes sense or just a way to get my money?
northernford is offline
post #2 of 16 (permalink) Old 01-27-2013, 10:13 PM
chuckster57's Avatar
I am subscribing to this thread because I think it's BS, and I want to know for sure.
Sent from AutoGuide.com App
Train Horns:
PM please not visitor message
chuckster57 is online now
post #3 of 16 (permalink) Old 01-28-2013, 12:58 AM
there are "thin fuel" parts available- very expensive. Designed more for use in the Arctic.
Consists of transfer pump liner and blades and governor thrust washer built with tougher materials.
Evel486 is offline
post #4 of 16 (permalink) Old 01-28-2013, 08:22 AM
drinkypoo's Avatar
My Photos: (25)
how expensive is very expensive? that sounds like a good thing to do anyway.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #5 of 16 (permalink) Old 01-28-2013, 08:58 AM
I'll bet someone in that shop exchanges his summer air for winter air in his tires.
'92 F350 crew cab, dually, 7.3L IDI, ATS088 turbo, Moose pumped, bb coded, e4od, 3.55 gears, 2wd
'Fuging free WMO fuel with a WVO Design Extreme unit
Blind DrIver is offline
post #6 of 16 (permalink) Old 01-28-2013, 10:07 AM
There are the Arctic pumps, these are designed to run straight Kerosene. Using a additive will help the pump live even with no 1 diesel.
Alvin Mitchell
Pablo Montana
1983 F250 4X4 4.10 gears 4 speed dana 50 center/44 outers Dana 70 rear
Mitchalvin is offline
post #7 of 16 (permalink) Old 01-29-2013, 10:43 AM
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
The military uses pumps with hardened parts for wear resistance since JP8 (jet fuel) is a very dry fuel and doesn't lubricate very well.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
post #8 of 16 (permalink) Old 01-29-2013, 11:36 AM Thread Starter
so it's possible the shop up here uses ips with more durable parts but his price is about $700 for the pump and $500 to install and time. i've seen pumps on ebay for $350. i think i can wrestle through replacing the pump but timing one sounds over my head. on a side note, do the 7.3 and 6.9 use the same pump?
post #9 of 16 (permalink) Old 01-29-2013, 11:56 AM
NH2112's Avatar
$500 to install and time? That's nuts. Installation takes maybe an hour if you're halfway handy with tools. Timing is a little more, but for under $500 you can buy your own timing light & adapter.
Phil
NH2112 is offline
post #10 of 16 (permalink) Old 01-29-2013, 12:24 PM
drinkypoo's Avatar
My Photos: (25)
don't buy a random eBay pump. get one from someone reputable, like one of the site sponsors, midwest, oregon...
post #11 of 16 (permalink) Old 01-29-2013, 06:16 PM
From what I recall a pump built for kerosene uses different internal parts for the lack of lubrication the fuel provides. Nozzles also have a different anti-drip to prevent it from sticking when the engine is under full load for extended periods of time. To be perfectly honest I wouldn't waste my money purchasing it unless your going to only burn kerosene.
I know it can get cold up in Alaska but my truck started just fine after the block heater had been on for three hours in -40C and the only thing I do is add CRC fuel conditioner to replace the lubricity that the ULS diesel doesn't have.
1993 7.3 IDI, crew cab, long box, 4x4 and a half, XLT with ATS turbo.
Glowshift Boost, Trans, Pyrometer gauges with glow shift pod.
Devdg is offline
post #12 of 16 (permalink) Old 01-29-2013, 09:17 PM Thread Starter
thanks guys, i'll look around on one of the site sponsors. i would rather do it myself so i'll spend some time researching replacing and timing the ip. anything special to know about timing lights and adapters?
post #13 of 16 (permalink) Old 01-29-2013, 09:37 PM
Arctic fuel parts for DB2 7.3 applications
Gov thrust washer-$22.75
Driveshaft-$212.19
Transfer pump liner-$72.81
Transfer pump blades-$22.56 ea ($90.24)
Prices are in Cdn dollars and are in addition to costs to rebuild the pump.
As NH2112 said they are pretty much only used in the military to run on JP8.
BTW- at our shop rate to re & re the IP, set the timing, fast idle, and TPS if equipped is under $200.
To northernford- hiring a shop to set the timing after you install the pump should run under $50. To buy a good diesel timing meter could cost up towards a $1000
Evel486 is offline
post #14 of 16 (permalink) Old 01-29-2013, 10:45 PM
Driveshaft-$212.19
Where are you located?
Devdg is offline
post #15 of 16 (permalink) Old 01-30-2013, 12:20 AM
Northern BC. (Prince George)
Evel486 is offline
