IP...Manual or Electric? That is the question! - Diesel Forum - TheDieselStop.com
Old 09-18-2007, 09:46 PM   #1 (permalink)
Cjhstang's Avatar
suggestions?
Where do ya find an electric pump for these? Do they mount in the same place as the manual? Is it a complicated swap? and is there much of an advantage??
Thanks!
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
Old 09-18-2007, 10:39 PM   #2 (permalink)
Re: IP...Manual or Electric? That is the question!
electric IP?? you mean lift pump?
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
Old 09-18-2007, 10:46 PM   #3 (permalink)
88beast's Avatar
i dont think they make them too reliant on the mechanical pump sets timing etc and it would then need ele ignation box or the likes to control the injection time and that just too expensive
but may be wrong
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 09-19-2007, 10:50 AM   #4 (permalink)
Send a message via AIM to VD350
Napa carries electric fuel pumps for under $40, all you need is a max of 7psi. Find a spot on your wiring harness that only gets power when the key is turned (And make sure its not your gps, otherwise it wont get power all the time), take one wire of the pump to that, then ground it. cut the hose that goes to your fuel filter and attach both ends to the pump. The mounting bracket i took to my alternator tensioner bolt. Mounted up nice. About a 15 min job once the power is found.
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 09-19-2007, 11:40 AM   #5 (permalink)
try and mount the pump just ahead of the switching valve--that way its pushing the fuel forward--instead of pulling it--
94_turbo is offline
Old 09-19-2007, 11:49 AM   #6 (permalink)
88beast's Avatar
are you guys thinking fuel pump or the pump on the engine that controls when the fuel is delivered to the injector?
88beast is offline
Old 09-19-2007, 01:46 PM   #7 (permalink)
I know of no Electric IP to put on these machines so I am assuming he meant an electric fuel pump to replace the mechanical lift pump.
www.Fordemblem.com
VD350 is offline
Old 09-19-2007, 02:16 PM   #8 (permalink)
88beast's Avatar
got ya thats what i thought
88beast is offline
Old 09-19-2007, 03:51 PM   #9 (permalink)
So what do you do with the old pump? Do you remove it? Then I guess that you would need a plate or something to cover the hole. Can you just leave it in place and not worry about it and just leave it disconnected?
1994 duel cab F350 Ford with IDI Turbo 7.3 VIN K
130,000 miles and rolling.
OPTLOCK is offline
Old 09-19-2007, 04:32 PM   #10 (permalink)
just put the new pump in. Mine failed so i through an electric one on and never played with the lift pump.
www.Fordemblem.com
VD350 is offline
Old 09-19-2007, 05:44 PM   #11 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: OPTLOCK</div><div class="ubbcode-body">So what do you do with the old pump? Do you remove it? Then I guess that you would need a plate or something to cover the hole. Can you just leave it in place and not worry about it and just leave it disconnected?
</div></div>
Most folks take the old pump out and cover the hole with a chevy block plate. I'm not sure what engine type (454 maybe?), but I know I've seen it on this forum, just do a search for it...;-)
88 Ford F250 XLT Lariat, 2WD,7.3L IDI NA, C-6 auto, 4.10, 275000Mi.
04 Dodge 2400 Quad-Cab Long Bed, 2WD, 5.9L HO CTD, 6 Speed Manual, 3.73, 140000Mi.
netzgeist is offline
Old 09-19-2007, 05:56 PM   #12 (permalink)
it will look like this
http://farm1.static.flickr.com/159/3...d0d2a5.jpg?v=0
1993 Ford IDI 7.3L
F-250
Class 5 hitch
D load tires &lt;img src="/ubbthreads/images/graemlins/frown.gif" alt="" /&gt;
super cab
18x,xxx miles.
Purchased 9-22-06
Old 09-19-2007, 06:01 PM   #13 (permalink)
hesutton's Avatar
My Photos: (30)
A lot of good information in this old post about putting on an electric fuel pump.
Click Here
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
hesutton is offline
Old 09-24-2007, 01:54 AM   #14 (permalink)
The blocking plate you need is for a big block Chevy like someone mentioned above (454). The block is machined with a circular ridge that the plate will ride up on if it's a bit oversized, and leak. Mine rode up on the ridge so I ended up grinding the plate down a bit for a snug fit.
When I overhauled my 6.9L, I found pump arm parts in the oil pan and a lot of damage to the camshaft pump lobe. Red pump is the way to go.
Aubrey-Chinook, WA
87 F-350 XLT Lariat standard cab 2wd DRW, 6.9L and C6 w/cooler, 4.10 LS. Hypermax Turbo with 3-1/2 exhaust, US Gear OD, Powershot 2000 LPG. Cupholders and accumulated rust.
Aubrey is offline
Old 09-25-2007, 11:39 PM   #15 (permalink)
GenLightening's Avatar
Make sure you don't get a plate with the Chevy logo on it!
1988 Chevy CC DRW w/a 7.3L IDI w/Banks Turbo
E4OD w/Baumann Transcommand
Racer-X triple disc TC
US Gear Exhaust Brake
4.10 Chevy Diff
GenLightening is offline
