Old 04-05-2008, 06:09 PM   #1 (permalink)
IP pump possibly losing prime
i have a 94' idi turbo, after the truck sits for an extended period of time (8 hours or so) it wont start. there is fuel coming out of lift pump but nothing out of IP. i just put a new fuel filter on it. any info would help.
94' f250 150k, greasecar veggie oil kit
gohdsl is offline
Old 04-05-2008, 06:34 PM   #2 (permalink)
NCheek's Avatar
Check the return lines on the top of the injectors, the plastic fittings and o-rings dry up and leak air into the system.
-Nick
My Daily Driver:
1986 F-250 2WD, Regular Cab, LWB, 6.9, T-19, Sterling 10.25", open 3.55's, XLT Lariat, Texas Sesquicentennial Limited Edition, No Restrictor Plate, manually switched high idle/advanced timing, and an awesome custom shift knob thanks to Bruce Roosa / Koolknobs.
279,000 miles and counting, hoping for a US Gear OD and a Hypermax Turbocharger one day.
My first truck:
1982 F-250 4WD, Extended Cab, LWB, 5.8, C6 to T-19 swap, BW 1345, Dana 44 TTB/Dana 60 Semi Floater, open 3.55's. About four different colors (not counting rust), currently on loan to my little brother. Maybe one day it can be home to a 6.9L too.
Work Truck:
1992 F-700 Flatbed w/ dump, 7.0L BIG BLOCK GASSER, 5-speed trans (Clark?), 26,000 lb GVWR. Rides like a tank
NCheek is offline
Old 04-05-2008, 07:21 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
What do you mean none coming out of the IP.......... Did you prefill the filter before installation with fuel additive or fresh clean diesel......... fill via the outer ring of holes only. Never use the drainings from an old filter..... If you did not fill the filter then you have introduced air in the injection pump and system........ You could try a complete start...... GPs, foot to floor and crank for 20 seconds......... wait 1-2 minutes and try again.......if it does not start. How good are the batteries....... it must crank over faster than you can count RPMs.
Do a pressure and flow test of the fuel pump at the Schrader valve on the filter header (FSS- fuel shutoff solenoid disconnected on IP). Remove the tire valve core and hook a hose and pressure guage on it should see 4-6 psi when cranking engine over. Then do a fuel quantity test same place, should see 1/3 pint in 10 seconds of engine cranking, route fuel to a suitable container with a hose.
If there is a problem with the lift pump and you are changing it, ensure the new pump comes with instructions as to correct installation procedure if it is the newer model pump with the almost straight arm.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 04-05-2008, 08:40 PM   #4 (permalink)
the filter had already been bled out with new diesel and the system had been running fine for a 2 weeks, then a couple of days ago and yesterday it wouldnt start after sitting for two days of not having been run, but once i do get it started it runs fine it just takes a lot of cranking or a squirt of ether to get her goin and it only doesnt start after it sits. the batteries are good they're only 2 months old. i didnt see any fuel leaking from the daisy chained return lines on the injectors.
gohdsl is offline
Old 04-05-2008, 09:01 PM   #5 (permalink)
Snotzalot's Avatar
Any chance your fuel gage is at or below 1/4?
Regards,
Paul - Pocono Mtns. USA '90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, 10 oz. Bars Stop Leak and No ELC!
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 04-05-2008, 09:14 PM   #6 (permalink)
suv7734's Avatar
There may not necessarily be fuel leaking out of the return line caps but they can allow air to enter. There is a very small amount of pressure when the engine is running but it may not be enough, in the case of a small leak, to show fuel.
1988 F350 CC 4x4 SRW, 7.3 Banks non-wastegated turbo, C6 w/ HD torque converter, Tru-Cool 4590 trans cooler, Highjacker 'softride' 4" lift, pre/post luber, coolant filter, Racor fuel filter/separator, pyro and boost gauges, Progressive 16x8 wheels, 285-75x16 rubber, 3" downpipe into 4" straight pipe over the rear axle and into 5" SS tip. 1994 Alpenlite 33' 5th wheel trailer
suv7734 is offline
Old 04-05-2008, 10:39 PM   #7 (permalink)
the tank was above a quarter, there is enough fuel to where it shouldnt be an issue.
what should i do to fix the possible leaking return lines, do i need to replace them and where do i need to go to get them?
gohdsl is offline
Old 04-05-2008, 10:50 PM   #8 (permalink)
NCheek's Avatar
Replacing the caps, o-rings, and hoses should fix your problem. Midwest Fuel Injection has a kit, but it also includes the copper washers.
7.3 L Ford Diesel Fuel Injectors Fuel Pumps Accessories
-Nick
My Daily Driver:
My first truck:
Work Truck:
NCheek is offline
Old 04-05-2008, 11:27 PM   #9 (permalink)
[quote=NCheek;1549282]Replacing the caps, o-rings, and hoses should fix your problem. Midwest Fuel Injection has a kit, but it also includes the copper washers.[quote/]
do you know of any parts stores that might have them on hand or be able to get in a day or two?
gohdsl is offline
Old 04-06-2008, 01:33 AM   #10 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Where are you located........ someone may know of a place near you.....
How tight did you make the filter........ requires hand tight plus 1 turn with a filter wrench. Any wet spots on the filter header or base. Did you lube up the new oring and top seal.. is the drain shut.
Old 04-06-2008, 06:10 AM   #11 (permalink)
Snotzalot's Avatar
Regards,
Old 04-06-2008, 08:33 AM   #12 (permalink)
Look here too - A.D.S. Service Member Locations
1994 F250 7.3 IDI E4OD
rkpatt is offline
Old 04-06-2008, 09:53 AM   #13 (permalink)
im in kentucky/ohio area, i hand tighten the filter then used a wrench i have changed it before and have never had this problem using the same method and i did lube the filter o-ring, the drain should be shut i didnt mess with that when i changed the filter.
gohdsl is offline
Old 04-06-2008, 10:15 AM   #14 (permalink)
cdnsarguy's Avatar
My Photos: (66)
The only thing we missed was to place clear hoses on the filter header to #1 injector and IP to #2 injector and see where the air is entering........
Do some reading if you have not been there before ........
Ford diesel 6.9 7.3 IDI
