Jasper 7.3 info - Diesel Forum - TheDieselStop.com
Old 12-21-2008, 11:46 AM   #1 (permalink)
Jasper 7.3 info
Where would the rebuild tag on a jasper 7.3 be located on an engine. Can you take a number off the rebuild tag, contact jasper and find out if the motor was sleeved on all cylinders. Also would the tag indicate if the motor was a drop in or long block? Thanks, Remote
1989 F-250 4x4 C-6 7.3
1991 F-250 4x4 E-4OD 7.3
1989 F-350 4x4 5 speed manuel 7.3 (present project truck)
1989 F-350 4x4 E-4OD 7.3 (4 door) (future project)
John deere 450C Crawler
Ford 6610 4x4 Tractor
Diamond Rio Dump Truck
Chevy Dump Truck
International Semi
remote is offline
Old 12-22-2008, 09:55 AM   #2 (permalink)
Production Tag on JASPER enigne
Standing at the rear of the engine, on the left side to the rear of the oil filter there should be a red sticker with white numbers. This is a 6 digit production number. If this is an engine that has been purchased since March of this year this number will also be on a label on the valve cover.
That production number will tell us anything you want to know about the engine.
I hope this helps.
Mike
jasperguy is offline
