Old 07-28-2006, 12:29 PM   #1 (permalink)
Just got a 94 turbo, Few concerns
I picked up a 94 tubo 4x4 supercab a few weeks ago with 264,000 miles on it. The guy I purchased it from said it had a rod knock as it started making a knocking noise about two months ago. I have been told on these motors the injectors are prone to go out and can cause a knocking noise. Is there any way to test to see if it's the injectors? Other than changing out all the fluids is there anything else I should do/check?
thanx
1994 F-250 Supercab 4x4 7.3L IDI Turbo
"The world is a dangerous place to live, not because of the people who are evil, but because of the people who don't do anything about it."
-Albert Einstein
phaux is offline
Old 07-28-2006, 02:17 PM   #2 (permalink)
Re: Just got a 94 turbo, Few concerns
Yes you can check the injectors. With the engine running, crack open the injector line nuts (5/8" wrench) on top of the injectors one at a time. When the knock goes away you have located the cylinder.
Now here's the thing, this will take away the knock whether it's a loose rod bearing or a bad injector. You need to swap the injector for a known good one to see if the knock follows the injector or not.
Personally I would buy a new set of injectors and an injector install kit before moving around injectors. The reason is that once you take off the fuel return caps to move the injectors, the O-rings will leak fuel.
It's a leap of faith to buy new parts, but a faulty injecotr is much more likely than a bad rod bearing.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
