Old 03-22-2005, 11:55 PM   #1 (permalink)
My Photos: (5)
just to stir up the additive discussion pot
>>> click here <<< to see lucas additive in motion - as found on Bob Is The Oil Guy site.
Me I'm a non oil additive kind of guy but thought this would be a good discussion for us...
Travis
Will Work For Diesel Fuel.
argve is offline
Old 03-23-2005, 12:16 AM   #2 (permalink)
My Photos: (23)
Re: just to stir up the additive discussion pot
i have one experience with the stuff:
oil change before last one (a little over a year ago), on a trusted friends advice i used a couple quarts to see if it would ebb my leaks. it didn't.
i never saw any evidence of foaming, though. or any other ill effects for that matter.
don't see a reason to use it now that i found the basement [img]/ubbthreads/images/graemlins/laugh.gif[/img] & learned about Blackstone.
Frank
Unofficial BOOB man (unofficial BUTT division: brotherhood of un-turboed trucks)
meet Big Black, my 1992 International 3/4 ton pickup wrapped in a Ford skin: 2wd, LWB, N/A 7.3, ZF5, 3.55s. 249k miles.
Amsoil bypass & AF. 3" true duals. no soup for me. 'ghetto' fresh air. Baja block drains. bottle broke. slobber tube. true dual 3" straight pipes. now a TRUE oil burner - she's drinking 15% Bunker Fuel (WMO).
soulpatchfr is offline
Old 03-23-2005, 01:02 AM   #3 (permalink)
d9d
oh man...Travis...yer gonna have me owing James another cigar! [img]/ubbthreads/images/graemlins/grin.gif[/img]
My Rig: 1991 F350, 4x4, 5-spd, 7.3na, 4.10 solids, std. cab, flaking factory blue... [img]/ubbthreads/images/graemlins/grin.gif[/img]
My other diesel is a...
Hydra 35-ton Excavator, 6V71T; Isuzu C201 genset;
'71 VanPelt Pumper, Cummins 855 Turbo
There used to be a link here, to some useful IDI-diesel tech info; but it was chopped out by others, in a vain attempt to repress the very essence of the internet: linking!
sigh...
d9d is offline
Old 03-23-2005, 02:32 AM   #4 (permalink)
hm... looks like bad news for lucas [img]/ubbthreads/images/graemlins/eek.gif[/img]
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 03-23-2005, 03:12 AM   #5 (permalink)
While we're into "oil", this one is also pretty interesting : http://www.eaa49.av.org/techart/str_oil.htm
1991 F-350 XLT Lariat 4x4. Metallic Midnight Blue over Silver Gray.. Canadian Made. Now has 82000 miles. Std Cab SRW-7.3 With a Banks Stinger Kit. ZF-5 speed- 4:10. Five rear overload springs rated at 3000 lbs, Smitty Built side step tubes, mounted to frame with 1/2 " steel plate.. SteelHead sliding rear bumper. SteelHorse overhead panel with a Cobra 25. Dash mounted compass and altimeter, pillar mounted Banks pyrometer. 11.5 FT camper in the bed 99% of the time. Camper has been restored all the way out from it's frame. Camper has two #30 batteries, good for a week dry camping in the woods..
--- Two 1978 Bronco's- One stock 400 cu" and one Bombed 406 cu"--- 1972 E-200 van. 302 cu"--- 1975 F-600 with 361 cu" Industrial engine.
HiWayMan is offline
Old 03-23-2005, 05:16 AM   #6 (permalink)
My Photos: (5)
hiway,
that was an interesting link. Never knew how a multivis oil worked just knew that it acted like thin oil when cold and thick oil while hot. I wonder why then engine makers/auto makers don't push the straight weights as hard as they do the multivis oils... couldn't be because they want to sell more product could it [img]/ubbthreads/images/graemlins/wink.gif[/img]
Travis
argve is offline
Old 03-23-2005, 06:22 AM   #7 (permalink)
- I can confirm the information given via HiWayMan. My internal source at Exxon tells me to use oil with as little span as possible. Straight weight is difficult to obtain in Norway, so she advises strongly to use 15w-40 rather than 10w-40 or 5w-40, if possible.
Torstein
E350 '93 7,3 Diesel IDI/NA E4OD RABS II Oslo Norway
200 000 km and counting
SAAB 900 '91 160.000 km
SAAB 900 '83 300.000 km sold
VW Caravelle TD '88 40mpg fully loaded(sold)
Citroen BX 16 (crashed (not by me))
Misc American leftover: Diamond ('46), GMC('49), Dodge ('49)
Torstein is offline
Old 03-23-2005, 10:15 AM   #8 (permalink)
Hi Guys,
I've used this oil in my tranny, power steering, guns, knives, radiator, there are numerous industrial & military applications for this product. I generally buy a case of the 16oz. size bottles and put in a lot of things.
http://www.militec-1.com/
jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system.
http://community.webshots.com/user/jl_mendoza
jlmendoza is offline
Old 03-23-2005, 11:10 AM   #9 (permalink)
My Photos: (12)
I think (oil guy Bob) is a little slippery. I have for 7 years and will continue to use Lucas oil products. They do raise oil pressure and lower operating temperature and have saved many derby motors while running a half hour to fourtyfive minutes with no radiator.
Now how many of you boys have added lucas to your noisy transmissions and rearends and was pleasantly suprised with the quiets. and I bet no
foaming at service time either. I wonder how many rpm's old Bob spun his gizmo to ?
1979 f350 4x4 6.9 idi everything new or better than.
idieselman is offline
Old 03-23-2005, 11:58 AM   #10 (permalink)
Travis, they wouldn't do that to us.. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
HiWayMan is offline
Old 03-23-2005, 12:13 PM   #11 (permalink)
Jerry, it looks impressive.. Maybe we can get the "Oil Guy" to test it for us...
HiWayMan is offline
Old 03-23-2005, 01:30 PM   #12 (permalink)
Tried it with fresh fluid. Made it shift harder and didn't notice much noise reduction with the ZF. Not sure if too great of a percentage of additive/MercIII. Switched to redline synthetic and shifted smoother and mucho quieter. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Just my experience.
Ron [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Ron
My Photo Gallery
Goldie 1990 F-350 Custom 4x4 C/C DRW conversion. 7.3L Banks non-waste gated turbo, ZF-5 with 4" custom Exhaust complimenting a RDT venturi system, Autometer Pyro and boost 2 gauge pillarpod and your standard compliment of mechanical gauges. Clutch pedal Heim joint mod.
The Beef 1989 F-350 Lariat C/C DRW 7.3L N/A, ZF-5. Clutch pedal heim joint mod. Original price $500.00.
Currently slated for an extreme makeover ground up restoration.
Mater 2007 F-250 Lariat 4x4 6.9L IDI, T-19 trans pushing a 7'6" Western plow. Completely assembled from the tires up!
I got your "Jeep Thing" now it burns when I pee.
Dsl_Dog_Catcher is offline
Old 03-23-2005, 08:31 PM   #13 (permalink)
I was just considering whether to switch to SAE30 shell Rotella-T for my 6.9 in the summer. In Gainesville, we're likely not to see anything below 30* until November or December from here on out [img]/ubbthreads/images/graemlins/cool.gif[/img]
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 03-23-2005, 08:40 PM   #14 (permalink)
Yeah 30 weight for above 30deg and 10w40 for below 30/ But I use 10w40 year round with reg oil change every 5k miles/ if not sooner/
Interesting fact the Cummins engine recommended oil change is every 1500 miles/ Yep saw it myself in the owner's manual..
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
truckdrivindave is offline
Old 03-23-2005, 08:47 PM   #15 (permalink)
cdnsarguy's Avatar
My Photos: (66)
1500 miles is the same for our Navistar in severe duty service like a school bus, towing etc........
Proud Canadian BOOB man too!!
cdnsarguy is offline
