Leaking Fuel Filter/water separater - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 12-10-2010, 08:01 PM Thread Starter
I had a mechanic install the fuel filter about two years/10,000 miles ago. Now I noticed it's leaking fuel. Before I change it out myself, I thought I check here and see if someone can tell me how do I check to see if its on tight enough or if something else could cause it to leak. Just in case I need a new filter I bought a NAPA Gold 3217 filter.
kellogg is offline
post #2 of 20 (permalink) Old 12-10-2010, 08:04 PM
chuckster57's Avatar
Where is it leaking from? If it's leaking from the top of the filter where it screws onto the filter header, then it might be on TOO TIGHT..
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 20 (permalink) Old 12-10-2010, 08:24 PM Thread Starter
Looks like the fuel is seeping out between the bottom of the filter and the screw on cap on the bottom.
kellogg is offline
post #4 of 20 (permalink) Old 12-10-2010, 08:54 PM
Both sides of the filter have a rubber gasket and IIRC the bottom one is like an O ring. Lots of people think you have to put these things together with a filter wrench and torque it..I would just replace it after you coat the new gasket with fresh fuel or petroleum jelly.
Train Horns:
post #5 of 20 (permalink) Old 12-10-2010, 09:08 PM Thread Starter
Are you talking about replacing the entire filter or just the gasket? Is there a rule on how tight to make the connection? Like for regular oil filter, you hand tighten it three quarters of a turn after the rubber gasket touches the base. Will three quarters turn also work on the fuel filter?
kellogg is offline
post #6 of 20 (permalink) Old 12-11-2010, 12:42 AM
lexxxel's Avatar
most of the filters have instructions printed right on them, for how much to turn past contact point
if the filter is leaking underneath at the bowl, it is leaking from either the drain port, or the water in fuel sensor port.
You can fix both these with new orings.
however, you can also get around the problem by purchasing the WIX filter with the built in bowl. That's what I did and it eliminates leaks. I used the one without the water in fuel sensor, as they don't come with a new sensor, you have to use your old oem one, and if that's what's leaky, it'll keep leaking
I do plan to fix my oem bowl at some point, but for now, the wix built in bowl filter works great
plus after 2 years, it's time to change yours anyway
'91 F-250 7.3idi XLT Lariat Supercab
Non-Turbo, Bone Stock
E4OD 4x2 4.10 non-posi
6 digit odometer
122,000 miles (197,000km)
still Minty Fresh
Sold my old 90 reg cab @340,000 miles (550,000km)
Still running I'm sure...
lexxxel is offline
post #7 of 20 (permalink) Old 12-11-2010, 10:27 AM
drinkypoo's Avatar
My Photos: (25)
At my local Napa the filter with the built-in bowl is $10 cheaper than the one without it. YMMV. I had to buy one (or go looking for a new bowl) because the bowl was overtorqued on the filter on the truck when I bought it, and this apparently straightened threads on the filter or the bowl to the extent that it could not be backed off. Works great.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #8 of 20 (permalink) Old 12-11-2010, 10:30 AM
drinkypoo's Avatar
My Photos: (25)
Oh yeah, and, they don't come with a new sensor but they DO come with a new O-Ring for the sensor. The sensor should be readily available if you hunt the occasional junkyard and I think we'd all like to know if we have water in our fuel.
post #9 of 20 (permalink) Old 12-11-2010, 11:38 AM Thread Starter
I'll get to work today to replace the filter. Thanks to everyone who replied to my post. Your inputs were very much appreciated.
kellogg is offline
post #10 of 20 (permalink) Old 01-24-2011, 09:28 PM
ghostcat's Avatar
Location: little Browns Moutain, Weaverville, Peoples Replublic of Kalifornia
I cannot seem to find anyone who can tell me where to get the drain pet**** assembly or just the o rings. all i can find is a kit for later powerstrokes ( ive a 1988 NA IDI myself). any help here? im tired of getting the blank stare from parts counter guys.
ghostcat is offline
post #11 of 20 (permalink) Old 01-24-2011, 09:43 PM
ghostcat's Avatar
Evidently petc-o-c-k is a naughty word
ghostcat is offline
post #12 of 20 (permalink) Old 01-24-2011, 09:50 PM
Yeah it is
If you look up Tousley Ford parts ( site sponsor) and then just look in 1990 f350 and then type "fuel" in the search field, you can scroll down and find a part listed as "fuel/water seperator" 88-91 for $30.77..If nothing else call them, VERY easy to talk to and verify if it's the right part
Train Horns:
post #13 of 20 (permalink) Old 01-24-2011, 09:59 PM
ghostcat's Avatar
Originally Posted by chuckster57 View Post
Yeah it is
thanks, man. although it is a small achievement, you have just proved yourself smarter than a busload of partshouse employees
ghostcat is offline
post #14 of 20 (permalink) Old 01-24-2011, 10:16 PM
Thanks but I'll hold on the big bow and applause until It's verified to be what our looking for. I have worked on autos for the last 35+ yrs. and sometimes you have to use different logic to arrive at the same place.
Train Horns:
post #15 of 20 (permalink) Old 01-24-2011, 10:28 PM
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
Yeah, I'm sure we've all seen someone in Autozone or O'Reilly asking for a "high beam switch" and getting the deer-in-the-headlights look from behind the counter til someone mentions "dimmer switch." Which is really a misnomer, since AFAIK high beams don't put out more lumens, they're just aimed differently.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
