Lift pump replacement - Diesel Forum - TheDieselStop.com
Old 05-19-2006, 10:58 AM   #1 (permalink)
Greetings gang,
I was just told by the site's cumbersome and useless search engine that my search words were too short??? [img]/ubbthreads/images/graemlins/confused.gif[/img] ***?? Ok, so I surrender and ask my question:
Just got my Blackstone report and all is well EXCEPT I have 6% fuel in the oil- makes me nervous. So I figured that 144,000 clicks is a pretty full life for a lift pump and it could have a hole it the the diaphragm and just change it out as a starting point. Just wondered how messy a job is this- am I gonna loose oil and/or fuel upon removal? Next step is to pull all injectors and have them bench tested (although folks I have talked to don't think malfunctioning injectors could put that much fuel into the crankcase, plus they're only a year and 8000 mi. old). Thanks for the help- BTW, where's Okie been?
Keith
93 F350 CC Dually 7.3 Hypermax turbo 4:10 gears, ZF rower, K&N filter, home made ram-air, Hypermax 3.5" exhaust, LUK clutch, 150,000 mi.
Weezer is offline
Old 05-19-2006, 11:59 AM   #2 (permalink)
Re: Lift pump replacement
You may lose a little fuel from the lines when you let them go.There will be no oil comming out fo where the lift pump bolts on.Be sure to follow the instructions per lever orentiation.
1992 f-350.4x4 srw.rebuilt e4od.rebuilt injection pump. no soup bowl,no muffler,straight pipe.. 8 foot power angle Artic blade/7 1/2 ft p/a Fisher blade. 280,000kms and counting.Paint to come.
pnose is offline
Old 05-19-2006, 12:19 PM   #3 (permalink)
Thanks, Paul- yeah I recall the discussions about the need to position the lobe on the crank properly. Thanks for the reminder. A little diesel fuel- no problem...I put a dab behind each ear daily for cologne. I'm goin' in...
Keith
Weezer is offline
Old 05-19-2006, 06:41 PM   #4 (permalink)
Get a small mirror and peer into the hole after Lift pump removal, you easily see the cam.
You will see the the UP position only happens briefly every revolution.
After shutting the beast down, and waiting a few minutes, all of the oil is low, in the pan, no leakage really from the open lift pump port.
I am convinced that a lift pump that "checks out OK, is really leaky. And this is how air get into the fuel delivery system.
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 05-19-2006, 06:52 PM   #5 (permalink)
HamerDown's Avatar
Era...say again [img]/ubbthreads/images/graemlins/confused.gif[/img]
88 F 250 7.3 Super Cab XLT Lariat4X4...Cream Puff
81 Corvette...Pampered
Harley Shovel 88" Show Stoper...WOW
BBC 468 Jet Boat...Gotta get Wet!
It's the Women that cost me the $$$$
HamerDown is offline
Old 05-19-2006, 10:03 PM   #6 (permalink)
yea for as cheap as the lift pumps are and easy to change go with it first then my second culprit would be the INJ. pump
Aric
96 F-350 4x4 regularcab dually 5spd 4.10LS [color:"red"]Home made Bumper[/color]DIY open air intake hypermax dp 4" exhaust DIY exhaust brake [color:"red"]Dump bed[/color]
93 F-250 factory turbo 4x4 extended cab [color:"blue"]MyPics[/color] 4.10 5spd K&N filter ATS outler and down pipe 3in exhaust to twin 5" stacks tweaked wastegate turned up pump LUK clutch boost and pyro and much more to come[color:"blue"]Mickey Thompsons classic II 265 75 16 Courser C/T[/color]
Ford makes it IH shakes it
Don't worry about the mule just load the wagon
93turbo'd_animal is offline
Old 05-20-2006, 01:38 AM   #7 (permalink)
Be sure to use a flare nut (fuel line) wrench to loosen and tighten soft metal fuel line nuts. Soft metal needs a soft touch, specially designed to turn flare nuts without stripping.
Flare nut wrench:
http://img.photobucket.com/albums/v308/schugh/flare.jpg
Good luck,
Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
Old 05-20-2006, 09:55 PM   #8 (permalink)
My thought is that the lift pump may deliver the pressure and volumn, but due to age, it can allow air into the system. It is a theory, only that.
When a lift pump gets old it is so inexpensive, I see no reason to not replace it.
When someone reports hard starting, and has a lift pump that is original, yet the lift pump "Check's Okay", I believe in theory it is truely leaky!
IMHO
BB
Old 05-21-2006, 02:54 AM   #9 (permalink)
My Photos: (17)
Greetings gang,
Just got my Blackstone report and all is well EXCEPT I have 6% fuel in the oil- makes me nervous. So I figured that 144,000 clicks is a pretty full life for a lift pump and it could have a hole it the the diaphragm and just change it out as a starting point. Just wondered how messy a job is this- am I gonna loose oil and/or fuel upon removal? Next step is to pull all injectors and have them bench tested (although folks I have talked to don't think malfunctioning injectors could put that much fuel into the crankcase, plus they're only a year and 8000 mi. old). Thanks for the help- BTW, where's Okie been? Keith
The weather is great, so I'm out mowing my lawn and mowing M.I.L.s lawn. My hands are still vibrating from the damn "WeedEater". Both places have 1 acre of lawn. Also, my son is in Little League and Cub Scouts. I guess you could call me "A Bad Weather Internet Junkie". This being "retired" is a whole lot more WORK than I was lead to believe, especially in 95 deg weather. [img]/ubbthreads/images/graemlins/shrug.gif[/img]OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 05-22-2006, 10:08 AM   #10 (permalink)
Okie,
Glad to hear you're enjoying life- personally I feel the lawn mower is a midevieval torture device...I'd much rather move snow.
Thanks all for the advice. Install was uneventful, managed to remove the line using a line wrench. Seems to run a bit better now but the proof will be in the next oil analysis. Have about 450 mile pull ahead of me this weekend.
Keith
Weezer is offline
