Low oil pressure - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 09-22-2009, 09:34 AM Thread Starter
Coldiron's Avatar
Low oil pressure
We have an 87 F250 IDI and it has almost no oil pressure as per the oil pressure gauge when running at any RPM. using 15-40. when cold it is better but once it warms up it almost won't register. any ideas?
Coldiron is offline
post #2 of 8 (permalink) Old 09-22-2009, 09:43 AM
Snotzalot's Avatar
My Photos: (5)
Dash gauge or aftermarket gauge?
These motors don't run high oil pressure.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is offline
post #3 of 8 (permalink) Old 09-22-2009, 07:09 PM
thomasboyz's Avatar
my engine oil pressure was over half when i had my 7.3. for a year i replaced two oil pressure sensors. my oil wasnt gunky or anything so maybe just bad products. these engines arent prone to low end problems so its less likely you have a bearing or oil pump failure. well that also depends on your mileage and maintenence. make a signature that way we know info about you vehicle.
11' White Platinum F-350 dually 4x4 fully loaded
thomasboyz is offline
post #4 of 8 (permalink) Old 09-22-2009, 08:01 PM
cdnsarguy's Avatar
My Photos: (109)
Oil pressure is usually 10 hot idle and 30-40 @ 3000+rpm
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #5 of 8 (permalink) Old 09-22-2009, 08:07 PM
chuckster57's Avatar
Like Snotzsalot says dash or aftermarket. and if aftermarket what is the scale. Mine is 0-100 PSI with a 270 degree sweep. I can see 1 PSI change on the gauge.
Like Cdnsarguy says, I get 12 @ idle fully warmed up and it goes to 40 when I get above about 1000. I use DELO 15-40
Train Horns:
PM please not visitor message
chuckster57 is offline
post #6 of 8 (permalink) Old 09-22-2009, 10:07 PM Thread Starter
Coldiron's Avatar
I think the gauge is factory. the oil pressure is just touching where it says "normal" when it is started then drops to just below but still reading after it gets hot. I don't know how many miles are on it as the engine was replaced a while ago. it is my boss's truck so I don't know much about it. I am just concerned it will seize up or something with the pressure so low. he has it a bit over full right now I noticed but it didn't make any difference. thanks for the reply's!
Coldiron is offline
post #7 of 8 (permalink) Old 09-22-2009, 10:36 PM
Kevin 007's Avatar
Thats what mine reads to! but like the others mentioned...cant trust factory gauges
1984 F-250 6.9, T-19, BW1345, BB code injectors, low mileage, manual Beru Glow Plugs, D70 rear end. solid truck.
1985 Toyota Landcruiser BJ60, 5 bearing cam 3B 4cyl diesel, H55F trans. Best rig I have ever owned.
1981 Honda Trail 110.
Kevin 007 is offline
post #8 of 8 (permalink) Old 09-23-2009, 05:21 AM
Snotzalot's Avatar
My Photos: (5)
Put a piece of tape over the gauge and drive it!
Regards,
