LOw oil pressure at idle - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 04-06-2007, 05:21 PM Thread Starter
OK the deal is I have an 89 f350 7.3 diesel. Love this truck first diesel and never going back to gas. The issue iam having is the truck just recently started to have low oil pressure after it is warmed up at idle. We talking idiot lite on and my oil pressure gauge at the minimum. But only at idle. If i give it a little gas the pressure comes back up.From talking to a few mechancs there saying that its probly bearing wear. AHHHH. I was hoping i could get away with changing the oil pump but I iam still green with this engine any advice is very welcome. Thxs
robdog89 is offline
post #2 of 8 (permalink) Old 04-06-2007, 06:43 PM
Re: LOw oil pressure at idle
What weight oil are you running?
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #3 of 8 (permalink) Old 04-06-2007, 06:52 PM
Snotzalot's Avatar
My Photos: (5)
Replace your sending unit before you do any major repairs.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is online now
post #4 of 8 (permalink) Old 04-06-2007, 08:03 PM
cdnsarguy's Avatar
My Photos: (109)
Do a pressure test or hook up a manual oil guage.......
Our diesels only have 10 PSI at curb idle 650 RPM and 40-70 PSI at 3000+ rpm.
The OEM sender and guage are on/off switch at 7 psi......
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #5 of 8 (permalink) Old 04-07-2007, 12:38 PM
after the sending unit and mechanical gauge, it is probably the oil pressure relief valve in the oil cooler. pull off the oil cooler and see if its stuck open. even a little will have a drastic effect on oil pressure. the way i look at it is
new oil pump and bearings (rod and mains)= alot of money'
oil cooler header= 264 (if i remember corrrectly)
check that before doing bearings and save yourself some money becuase unless its knocking it probably isnt your bearings.
or you could do what i did and replace everything while your in there
good luck
matt
ASE Certified: Medium and Heavy Truck Diesel
Federally certified air brake technician
1990 F-250 7.3 IDI N/A 4x4 ZF5 Dana 60 front, LUK Clutch SMF, 215k
1991 Ford B700 6.6l School bus, Straight pipe
1987 Ford F350 Dump 4x4 c6, 38k miles, 8 foot meyers plow
2002 VW Golf TDI
1989 Festiva (my favorite)
1989 Saab 9000 Turbo
2002 Saturn SL1 (Daily Driver)
1950 Dodge Coronet
1996 F150 2wd 4.9 5 spd, 136k
90734x4 is offline
post #6 of 8 (permalink) Old 04-08-2007, 09:01 PM Thread Starter
Thanks for the advice. I'am going to replace the oil pump the cooler and sender. and but it all back in. I took the engine out to do a clean up on the engine and the bay. Thxs again.
robdog89 is offline
post #7 of 8 (permalink) Old 04-08-2007, 09:17 PM
If you are going to drop the pan, replace the oil pickup also. No matter how much you work at it, you can never get all of the hardened sludge buildup out.
post #8 of 8 (permalink) Old 04-09-2007, 01:28 AM
cdnsarguy's Avatar
My Photos: (109)
Now there is a ton of money.........possibly wasted. We here usually advise check things out first.......but you have aready removed the engine...
