Old 11-01-2006, 03:33 PM   #1 (permalink)
Lower flywheel sheet metal cover ?
I bought my 1994 F250 E40D with bottom teeth of the flywheel exposed . The sheet metal cover is missing . I presume that it was left off after a transmission R&R in the past . What is that part actually called and what will fit from other models ? - Thanks
1994 F250 7.3 IDI E4OD
rkpatt is offline
Old 11-01-2006, 03:42 PM   #2 (permalink)
Re: Lower flywheel sheet metal cover ?
check the threads. unless i was looking at it wrong, i think the holes in the ?bellhousing? are threaded. I have some holes stripped and the sheet metal is just hanging on there with two bolts. So maybey thats why its off... Its worth checking to see if you want to rethread or not.
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
Old 11-01-2006, 06:27 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
The part is called the Flywheel inspection cover.....
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-01-2006, 08:12 PM   #4 (permalink)
Powerstrokedogg's Avatar
Send a message via ICQ to Powerstrokedogg
you can find it at any junkyard, all E4OD/4R100s should be the same
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
Powerstrokedogg is offline
Old 11-01-2006, 09:00 PM   #5 (permalink)
You will need one off of a diesel E4OD. The diesel has the bottom of the bellhousing machined off, where a gasser trans does not. This is to allow access to the torque converter bolts, since the large diesel oil pan blocks access from the front.
I've found out the hard way, that lack of this cover can ruin the starter when water gets up inside it.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 11-02-2006, 06:53 AM   #6 (permalink)
HHHHHmmmmmmmmmm He has a ZF5.............
Jim
<font color="blue">[b]93-F250 (Super Duty), Extended cab, Long Bed, XLT, Gray & Black, 7.3L, New Injector Pump, New Injectors 4X4, ZF5 5 speed trany, 4.10 gears Limted Slip.</font>
<font color="red"> Click here to check out My $800 Texas Truck</font>
<font color="green"> My 30 ft Wilderness 5th wheeler after new paint job and striping.</font>
<font color="purple"> The 2004 IDI rally in July</font>
<font color="red">Life, Liberty and the Pursuit of All Who Threaten It </font>
ltl_jrw is offline
Old 11-02-2006, 07:55 AM   #7 (permalink)
hey jim, you getting old? [img]/ubbthreads/images/graemlins/smile.gif[/img]
1993 Ford IDI 7.3L
F-250
Class 5 hitch
D load tires &lt;img src="/ubbthreads/images/graemlins/frown.gif" alt="" /&gt;
super cab
18x,xxx miles.
Purchased 9-22-06
Old 11-02-2006, 09:02 AM   #8 (permalink)
Everyone's getting old. *sigh*
Old 11-03-2006, 06:55 AM   #9 (permalink)
Yep must be, [img]/ubbthreads/images/graemlins/eek.gif[/img]
ltl_jrw is offline
Old 11-03-2006, 08:14 AM   #10 (permalink)
My Photos: (23)
That's OK Jim. I recently told somebody with an E40D to do the lucky mod. LOL!
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
