Major Engine Fuel leak
Need some tech help. I noticed a drip of fuel under my truck last week. nothing major, then pulled up to a stop light the next morning (5:45 AM) and the smoke rolling off the truck in the head lights looked like if was on fire. Poped the hood and the whole front of the engine was covered with fuel. After it sat there was a huge puddle of fuel under the truck. I parked it and drove the wifes truck till yesterday. I degreased and power washed all of the fuel off and let it idle. Found a couple of drips under the lift pump so I replaced it. no more drips so I took it for a drive. Got back and the fuel is all over the truck again. It apears to be coming from the drivers side, under the P/S pump where the high psi pump (?) is bolted to the block. Just seeping at the gasket surface and running down the block sitting in the drive. The truck runs fine starts great and no power issues but this is not a safe condition in my oppinion and its making a MESS in the driveway. Can I rebuild this pump? or do I need to replace it?
1994 "K" F350 XLT Crew Dually Turbo, E4POS rebuilt@ 280K, 2WD, 300K miles, 4.10s, K & N, Air bags, Air horns, Goose neck, Campershell with custom air foil, Flexsteel Blue power leather recliners, 235/85's, Cobra 29, New Trans, Radiator, Straight pipe,
1996 F250 XLT stroker, E4POS, Super Cab, Short Bed, 2WD,4.10s, 235-85's, 200K miles
