Old 03-17-2005, 05:32 PM   #16 (permalink)
Re: Major problem with my BANKS turbo...need help!
Ok for boost numbers I am not sure because I havent attached the line to the gauge yet...I am going to go do that now and see what I can get. I know for a fact though that the turbo isn't seized because you can hear it very well since there is only a down pipe on it right now...should I turn down my IP some or what??? You said too much fuel I thought after a certain point it wouldnt do nothing except blow black smoke but it wouldnt reduce power??? If someone has the time to give me a call I would appreciate it because I am going to be away from the computer...it is 2546880043...thanks.
Will check back in a while
Daniel
(Late)99 F-250 XL-Work Truck Special -Super Cab-4x4-6 spd-LWB-Homemade cold air-Edge Evolution-straight pipe-3inch lift-280k miles
SOLD-89 F-350 Single Cab-SRW-Banks Wastegated Sidewinder-Straight piped-5 spd-LUK clutch-Single Mass Flywheel-Isspro gauges
nostroke is offline
Old 03-17-2005, 05:57 PM   #17 (permalink)
Go hook up your boost gauge, i don't think you need to turn down the pump unless you have the screw bottomed out, i don't think to much fuel is the right wording, i would say not enough air, to much fuel or not enough air wouldn't cause a loss of power like your saying.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 03-18-2005, 03:43 PM   #18 (permalink)
My Photos: (17)
I remember a post a while back where the rubber connector between the impeller housing and the air intake was old and weak. And when the turbo spooled up it sucked the boot shut [img]/ubbthreads/images/graemlins/eek.gif[/img]=no air =lotsa black smoke. Also, if you've left the ground wire to the GP controller off when you moved the controller or if a wire behind the HOT exhaust side of the turbo has been burned IT WON'T START [img]/ubbthreads/images/graemlins/shrug.gif[/img]. Check the wiring carefully. It worked before YOU messed with it. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]BajaGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 03-21-2005, 08:11 AM   #19 (permalink)
Check the waste gate if it has on. Stuck open? Good luck.
88 bronco 6.9 banks turbo, 91 f-450 7.3 non-turboed, 95 f-450 powerstroke.
brivers is offline
Old 03-21-2005, 01:27 PM   #20 (permalink)
hesutton's Avatar
My Photos: (30)
What are those boost numbers? Did you check to make sure your lines/wiring is safely away from the hot parts of the turbo? Anything new? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
DYNO YOUR IDI AT THE 2009 RALLY
hesutton is offline
Old 03-21-2005, 03:00 PM   #21 (permalink)
My Photos: (13)
I was waiting for Dan to chime back in, but he has everything set up correctly. I called him and we worked through the engine. Basically, he had everything set up correct but he was not seeing boost because he never drove the truck hard enough to need boost (non wastegated Banks). Once he finally was able to drive it hard, he got 5PSI at about 70Mph, I told him, if he strapped a load on his back and pulled a good hill, he will probably see 10-12 psi pretty easy. He was having a little bit of trouble with the idle and the truck dieing out, also had some small electrical problem. I think he is tinkering with it and fixing the little stuff. But overall, he got it handled real well and just didn't see boost cause he was working the truck hard enough.. So wish him luck, Dan sounds like a pretty great guy to have around. Alot of diesel driving friends down in Texas. Scotty
Semper Fi
Scott Beretz
2006 Dodge Megacab 4x4, Cummins, 6 Speed, Airbags, Quadzilla Commander, XZillaraider 2, 285/75R17 Toyo OC AT's
Pulls a: 3814SS Keystone Raptor Toyhauler w/Quads
beretzs is offline
Old 03-21-2005, 05:17 PM   #22 (permalink)
Well how can that be? He said it had about half the power after the turbo install, was it just his imagination?
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 03-21-2005, 05:17 PM   #23 (permalink)
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 03-21-2005, 06:53 PM   #24 (permalink)
My Photos: (13)
I think he was just mad because he spent so much timimg bolting up the system and didn't see any boost. I believe he was seeing RED. Anyhow, After he worked the truck a little and saw some boost, he discovered a few little things he needed to fix. I am waiting to hear back from him, about the outcome of the truck. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 03-21-2005, 07:20 PM   #25 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Like I said I tried it with the pump set a little higher than stock and now at max and no differance really.
Do we read into this maxed out (bottomed out) with no turn back for safety and no damage to the pump.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 03-21-2005, 08:17 PM   #26 (permalink)
My Photos: (13)
Pete, I told him to back it out just a hair, so he doesn't hurt anything. I am hoping to see a post from him once he gets the truck back under control. I think he just has a bunch of little things to take care of. I know how it happens, all the little things get you down, just told him to walk away from the truck for a day, then come back and usually the problems seem alot easier. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 03-21-2005, 10:24 PM   #27 (permalink)
My Photos: (16)
Sounds like he has the same Earlier Banks turbo that I have? Was it the square box non-wastegated?
He should be able to see more boost than that (5lbs) going up a hill without a load. I can get 9 to 10 lbs unloaded if I floor it up a hill. 5 lbs sounds light to me.
I also just replaced my Rubber Air Inlet Compressor Elbow which was collapsing at higher boost due to it being too pliable from age. The newer one is way harder.
Sounds like he is having air restrictions to the turbo?
2004 F250 164 Kilometers. Bought in Nov/08
My Pictures
Hugh Kennedy is offline
Old 03-22-2005, 11:11 AM   #28 (permalink)
My Photos: (13)
He may be having a problem with the inlet hose, but as far as getting the main part of the turbo set up, he is good. I think he still has a little tweaking and getting a new hose may be part of it. But other than that, at least he is running and able to see boost. After that, it is all gravy. Scotty
Semper Fi
Scott Beretz
beretzs is offline
Old 03-22-2005, 02:02 PM   #29 (permalink)
Well I thank everyone for all their help. I still have not got anymore than 5 lbs...yesterday I took it down the highway hammered it and got 5 lbs...let off and it died. Don't know the problem. I think the clutch is now fried though from the smell and the fact that when well pull started it again it took along ways of pulling before it turned over and when it started it ran like crap real bad black smoke and slow to rev so I shut her down and now shes forsale. I am in college and don't have the time money or effort to fix her. My loss is your gain...it is on ebay now item 4537784677...Thanks again
Daniel
nostroke is offline
Old 03-22-2005, 02:41 PM   #30 (permalink)
Buy it now for $1200. [img]/ubbthreads/images/graemlins/eek.gif[/img] Holy crap, he's letting someone steal it.
Steve
Eric -&gt; '92, F250, 7.3l IDI, extracab, longbox, one ton spring in the rear,Borg Warner 1356 transfer case, 12500lb winch. 280k km. Since purchased in June 2003 repairs include: ball joints, tie rod ends, all u joints, water pump, radiator, brake calipers, brake pads & shoes, rear drums, front wheel bearings & seals, rear axel seals, replaced transfer case, rebuilt rear differential, replaced bent drive shaft, replaced drive shaft support bearing, K&N air filter, dual 2.5" exhaust.
Mango is offline
