<span style='font-family: Comic Sans MS'><span style='font-size: 11pt'>So I was doin' a mileage check this weekend and when the first tank ran empty, I switched over to the other tank.....Bad Move. Learned my leasson there!! It didn't catch and the truck died! Got off the freeway and ran the batteries down trying to start it. Lucky I had friends along with their diesels and jumper cables. We used 2 sets of cables between the trucks and finally got it started. After a while, I noticed the battery guage slowly but steadily dropping voltage. I was 1 hour from home and decided to make a run for it. Made it home, barely. Tonight, the batteries were dead. I inspected the alternator, and found the large wire on the back of it melted off! Jumped the truck and measured 34 vdc on the alternator side where the 8 guage wire should be connected. The others on the small 3 pin connector were I think 13 vdc, 12.4 vdc, and 12.4 vdc.
Should I replace the alternator, have it rebuilt, or is it something else? Not really sure what the output should be with no load on it.
Hope someone can help.
thanks,
kevin</span></span>
__________________ '94 F350 Dually 7.3 <span style="color: blue"> IDI </span> <span style="color: red">Banks Sidewinder & Trans Command, 3.5" Exhaust </span>
<span style="color: blue">Gear Vendors Over/Under Auxilary Trans </span> <span style="color: green">Gambler 209 (THE Ultimate Bass Boat)</span>
Lance 880 Camper
It should be 13 or so, the dead batteries finished off the diodes in your alt, you need a reman, take it to a GOOD autoelectric shop and get all the upgrades put in. Heavier diodes, output terminal upgrade kit, those are the 2 I can remember from the electric shop days. There is more but the memory is first to go, right?
91 F350 crew cab 4x4 7.3 ats and intercooled with '04 ps cooler , ,coated rockers , balanced. very good power.
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. 2400 cc type4 engine, my baby
Invader sandrail, 1.8 jetta engine installing spinny thing soon.
83 300 sd ready to build a real hotrod engine for this one.
Misc. vw's scattered about.
Sounds like you have burnt out the diodes, probably from trying to recharge the dead batteries. There is a warning when you buy alternators to replace the ones on these trucks that you can damage the alternator if running the truck with less than fully charged batteries. It's meant to maintain the full charge, not recharge them when drained.
If you have an auto electric rebuilder in your area, You could have your alternator rebuilt. It'll most likely be cheaper, and it should perform like new. I prefer my local electric rebuilder over auto parts stores.
Edit: ahh, posting at the same time lol
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
BTW, there is a 130A alternator with internal regulator that fits these trucks. Save your pulley. The 130A alternator has a bigger front bearing and much better charge at idle. You have to get the earlier 130A frame type. Most advertised 130A alternators are for later serpentine installations but any autoelectric place will have the earlier frame model that bolts right onto our engines. The wiring change is minimal for the internal regulator.
Aubrey-Chinook, WA
87 F-350 XLT Lariat standard cab 2wd DRW, 6.9L and C6 w/cooler, 4.10 LS. Hypermax Turbo with 3-1/2 exhaust, US Gear OD, Powershot 2000 LPG. Cupholders and accumulated rust.
