Old 10-22-2005, 02:05 PM   #1 (permalink)
Metal shield between engine and manual tranny?
There is a metal shield that goes between the engine and the transmission on trucks with a standard transmission.
Does anyone know if the shield is necessary?
What is it's function?
Does anyone know how thick the material is?
I'm not having much luck locating one. If I knew the material thickness I would just make one at the shop. It may be fine without it but I'm concerened that the thickness may throw off the clutch travel and it may not have propper pressure or release.
I am converting from an automatic to a manual and want to make sure that I have all ofthe parts needed before I start putting it back together.
Thanks,
Ceejmo
CJ
The wife's truck: 1994 F350 Super Cab XLT 7.3 Diesel, was E4OD auto now ZF5 manual (See conversion notes)
See also(ZF5 Wiring)
My truck: 1990 Dodge D250 5.9 Cummins, Getrag 360 manual, Tweeked pump, straight pipes
Ceejmo is offline
Old 10-22-2005, 02:39 PM   #2 (permalink)
My Photos: (24)
Re: Metal shield between engine and manual tranny?
No, you dont really need it. Besides if you are converting to standard tranns the go with the luk flyweel (12") or the luky mod One member Luky_larue made it using the stock dfw and convert it to sfw.
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 10-22-2005, 03:41 PM   #3 (permalink)
It is an inspection cover and if it was my truck, I would want it in place. As the previous poster said, you don't need it.
'94 F250, 4X4, 7.3, E40D, 4.10, 126K
tim94f250 is offline
Old 10-22-2005, 04:56 PM   #4 (permalink)
I disagree that it is not needed. Not only does it keep water etc out of the clutch assembly, but it is a spacer that is designed into the system's dimensions.
While it "may" technically work without, it isn't right.
Look at it this way, the automakers have spent millions of dollars installing the metal spacers. They wouldn't have done that if they weren't necessary.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
