ive found i have too much free time so i was wondering if there were any cheap ways to mod these trucks?
i think its in the aircleaner idk is it the bowl shaped thing that directs air tothe engine? or is it just the metal plate infront of the intake to the cleanerbox?
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
Removing the "soup bowl" is probably the most common mod, if you have it.
Turn up the fuel if you have little to no black smoke if you have a pyrometer.
1985 F-350 6.9 IDI w/101k miles, RC, 4x2, DRW, 4.10 gears, ZF-5speed, 5" stack, manual glow plugs, flatbed, buckets and center console off a bronco and no soup bowl!
Pics.: My Truck
Up next: Turbo, full instrumentation, hydroboost brakes
You may have a restrictor plate and not a soup bowl, removal of the soup bowl makes the intake suction noise louder is all, adds no balls. However removal of the restrictor plate is a different story. See which you have, http://forums.thedieselstop.com/foru...te_id/1#import
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
well did some looking i have a soup bowl but i also have a plate infront of the whole going into the aircleanerhousing
i have the intake tube and box removed allready just air cleaner
i looked and yes i hace the soup bowl but not for long!!! anything else i can do?
Ram Air!!! atleast thats what i'm planning. The stock intake setup looks like ford decided to suffocate the engine. My plastic extension off the filter goes right into the insulation of the hood. Where does it actually pull air from???
So I'm plannin on grabbin a wide, tall single hood scoop, cut a hole in the hood, and get some padding to seal the hood to the air filter housing. Then just get the correct filter.
That should feed it plenty of cold air...with a little forced induction action with some speed. Shouldn't cost much more than 70$...as long as you have the right tools.
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
wow never thought of the hood scoop idea i like it and i may try i have tools out the ying yang if you get that lol
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 88beast</div><div class="ubbcode-body">
i have the intake tube and box removed allready just air cleaner </div></div>
Don't trash those pieces, I want them, had enough hearing the 7.3, I want to hear my radio and my cell phone. I did the aluminum clothes dryer ducting only to have vibration cut it at the air cleaner.
sorry man dont have them any more if i get ahold of some ill ship them out though i may buy a parts truck just to restore mine (paint a part then replace it) then ill ship them i may buy a new air intake for the scoop idea so if you or anyone else needs a stock intake let me no ill ermove the soupbowl if you want
