Ok have everything back together, Just waiting on my wire harness (had to order it from a junk yard all the way from oregon! i'm in pa!). yesterday was messing with trying to get it started (wo engine harness yet) that way when the harness is in the fuel should already be in the lines and can just plug it in and go.
ran a hard line to open the shut off valve, cranked the truck for a while, fired up for about 5 seconds then shut off (assuming that was just the fuel from the fuel filter). cranked a while longer giving breaks and letting the trickel cell charger do its job. I popped the rubber hose off the lift pump to check for fuel - didn't find fuel but as i pulled it open i could hear the vacuum that was still there. Cranked it for a while longer fired up then shut off immediately.
How long would you expect to have to crank to pull fuel through all of the lines?? When I had my drain back problem it would usually fire up before the batteries were totally dead. This is taking much much longer.
Is there a better way to be getting this fuel through my lines?
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
i had drainback and it got really bad it took 15 min of cranking while hooked to another vehicle to charge
i think priming the line may be in order take line off before ip and pour in fuel
then do the same before the pump ]
pushing the gas pedal wont help because the engine has the fuel pump on it so then it turns at engine speed so more gas wont help while cranking
an ele pump is also a good idea they arnt too expensive and you can leave the key on till you got fuel then try to start
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
Push in the schrader valve on the fuel pump and crank to it's full. Then crack ONE injector fuel line and crank until is has fuel, then do the rest of the lines.
Regards,
Paul - Pocono Mtns. USA '90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, 10 oz. Bars Stop Leak and No ELC!
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
I should prolly add i have sections of high pressure fuel lines from a gasser cause my old lines were all messed up. Don't think this matters but figured i'd through that out there.
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
That's interesting, I always open all of mine at once - I can to an IP fuel screw adjustment in less than 15 minutes from running to running condition, on my buddy's 6.9 tho I have to slow it down to maybe 2 or 3 lined at a time, still tho, never really had to do it one by one.
__________________ The more I drink, the more I drink, the more I drink...
'90 F350 XLT Lariat, reg cab, dually, 4.10s, factory tow package, Chevy hydroboost conversion, P3 brake controller - the Hay Express
