Old 03-09-2007, 09:32 AM   #1 (permalink)
Is my IP headed south?
Last couple days when I park my truck I get a puddle of diesel fuel under the engine. Its dripping off the oil pan, front of the bell housing and the turbo crossover pipe. I looked around the IP and noticed the valleypan was wet with fuel but I can't see where its leaking from, I'm guessing somewhere under the IP. Where does the valey pan drain go to? Would fuel draining through that hole in the back of it go all over the oil pan and bellhousing?
If it is the IP leaking does that mean I need a new one? I am assuming I have the original IP and injectors and I am about at 119K. The truck still runs fine and I get about 16/17 mpg city.
I am planning on taking a 200 mile round trip in a few days and hoping this job whatever it may be can wait till after that.
Thanks,
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
ClassicFordGuy is offline
Old 03-09-2007, 12:15 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Is my IP headed south?
It would drip off the adapter plate for the trans, down over the starter/bell housing. There is a drain hole under the IP for the main shaft seal (see my gallery) but there are several other plugs/seals external so any of them could be the leaker. If it is the original think rebuilt unless you can get just a seal replaced. The one on the advance arm is replaceable.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 03-10-2007, 03:01 AM   #3 (permalink)
My Photos: (17)
Check the triangular shaped cover for the fuel screw on the passenger side of the IP. The screws might be loose or the rubber gasket might be "Headed South". Also, check the steel line from fuel filter to IP connection. There is a rubber o-ring type connection there that might also be "Headed South". However, with 119k on the IP, it is getting very close to "Rebuild Time"/"Heading South". IPs usually only last 100k-125k miles. [img]/ubbthreads/images/graemlins/smokin.gif[/img]OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 03-11-2007, 12:28 AM   #4 (permalink)
I did turn up the fuel a few months ago so I may have weakened the seal for the triangular plate, if it's not that seal it must be leaking from somewhere underneath. Since a rebuild is probably in order do you guys know of a place to get rebuild parts or a rebuild kit as well as a place to buy or get directions on how to rebuild a factory turbo IP? I recall reading that an IP rebuild can be tricky but I'm cheap and stuborn and refuse to take any of my vehicles to a shop for anything other than alignment and tire balencting so any do it yourself rebuild advice would be great.
Thanks,
-Rob
Old 03-11-2007, 07:50 AM   #5 (permalink)
My Photos: (27)
You might want to change your mind on that one since you need about a $10,000+ test stand to do about a dozen or two calibrations, set and check umpteen clearances and internal adjustments, and on and on. I've got a Stanadyne 6.9/7.3 complete injection pump overhaul and step by step test stand calibration manual, and to sum it up, other than a few external repairs, there's reasons diesel truck shops send pumps out to a local IP/turbo overhaul shop.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 03-11-2007, 10:45 AM   #6 (permalink)
Rob
I'm stubborn like you are, I hate paying shop rates that rising a lot faster than the products I produce. But this is one of those times take off your pump and take it into a good local shop and get it rebuilt or shop around and get a rebuilt on line. There are some good on line diesel shops that are way cheaper in price than my local one. I've been in my local shop and seen his equipment. I know what he does when he goes thru a pump and he has thousands of dollars in test equipment to test it when it been rebuilt.Your cost for parts alone is probably going to be as much as a rebuilt pump because pump shops are going to get a much better price on parts.Also how are you going to know which parts are bad unless the part is scored? Most diesel pumps run on thousands of an inch in tolerances. When you get done rebuilding your pump you still won't know what you have, and you may end up tearing it down several times to get it to work. This is one of those times to spend $300 to $500 bucks, get something that should last a long time and with diesel at $2.50 to $3.00, it will probably pay for it self in fuel savings over a couple of years.
Greg
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
Greg77 is offline
Old 03-11-2007, 01:46 PM   #7 (permalink)
arthurgoboom's Avatar
There's a thread in the 6.9 or 7.3 forum somewhere about a guy that rebuilt his own pump. It worked out great, but he had like 20-30 hours in it if I remember correctly, and between buying the parts he needed and having a diesel shop calibrate the pump, it cost him $290. The $110 he saved, divided by 20 hours = $5.50 an hour rate. I'm assuming if we have these diesel trucks, we make more than that at whatever jobs we have. Moral of the story is, drop the pump off at a shop, go to work, pick it up a few days later, you'll be money ahead AND probably have a bit of a warranty.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 03-11-2007, 11:46 PM   #8 (permalink)
The adapters on top of the injectors for the return lines have 2 o-rings under each of them that on 2 of my previous trucks after 150K miles needed replaced. They are a cakewalk to change.
2004 F-350 6 pack. 6.0 4x4. 4" lift 35" toyo MT's 4" turbo back straight. Edge Juice Platinum. K&N intake. EGR disabled. Zoodad Mod. RedLine diesel fuel catylast. Heavy Equip./Truck Mechanic
bigmk01 is offline
Old 03-12-2007, 06:45 PM   #9 (permalink)
Send a message via AIM to KevinIH73IDI
would replacing those o-rings fix my problem with it smoking real bad when cold and breaking up at higher rmps? i just took it to the dealer today and they said it was timed dead on i have another pump but i was hoping to save that until later.. or should i just use that now?
maroon/white '93 IDI 7.3 with 102k miles
super cab, e4od, 4x4, red interior rockin the mercedes floor mats
glasspack to 5" tip in front of rear tire
new glowplugs and controller 8/06
pyrometer 7/07 right between #7 and 8 cylinders
spicer 50 split front axle, auto hubs
KevinIH73IDI is offline
