Old 08-08-2005, 11:46 PM   #1 (permalink)
gotmustang's Avatar
my truck smoke's alot ????????
my truck is a 1993 f-350 and it smoke's alot just all the time.like a gray or maybe white smoke.funny thing is the day i got it there was no smoke at all.this was just 10k ago,and about 2 weeks after buying it is the time it started it.is there some thing some one put in to shop smoking for a bit or what?help me out guys this is my work truck and my famly truck,my son and new baby girl so i dont need this thing to just shop on me.thanks for you time and help guys.and just let me know if you need any more info on it.the mi's are 240k
1993 Ford F-350 2x4 Crew Cab With a 8ft bed
7.3 N/A With 270.000 mi
New E4OD trans with 1500 mi
Looking for a turbo close to Fort Worth
gotmustang is offline
Old 08-09-2005, 12:56 AM   #2 (permalink)
Re: my truck smoke's alot ????????
How does it start? Does it fire up straight away? Or, does it take longer than it once did? I'm hoping that you are having an air problem, or your glow plugs are failing. To test your glow plugs, get a test light and clamp it on to the positive battery terminal. Unplug the connectors from the glow plugs and touch the test light probe to the tip of each glow plug. If the test light illuminates, the glow plug is good. No light, no good.
To check for air, depress the shraeder valve (thing that looks like a tire valve stem) on the fuel filter header. Also, look for any fuel leaking on the engine. Check the fuel filter, lift pump, injector pump, injectors, hard lines and the return lines. The return lines, o-rings and plastic caps are usually the culprit when air leaks are an issue. Let us know what you find.
'94 F250, 4X4, 7.3, E40D, 4.10, 126K
tim94f250 is offline
Old 08-09-2005, 02:14 AM   #3 (permalink)
sounds like air is seeping into the fuel system, most the time its either plastic injector Ts or the return lines. On the Ts they have rubber o rings that seal the plastic ts. Or maybe the fuel filter isnt seated or sealed right.
--Ryan
91 f-350, dually, 7.3 diesel. 2wd, 4.10 gears LS. E4OD. New injectors, lift pump, and fuel filter at current 85,000 miles. Autometer pyro and fuel turned up. 3" exhaust with walker "btm" muffler
http://community.webshots.com/user/olivera_149
olivera149 is offline
Old 08-16-2005, 03:26 PM   #4 (permalink)
gotmustang's Avatar
it does take a long time to fire up.this just happen a mo ago.it's not air or leaking fuel.any more info
Old 08-16-2005, 03:59 PM   #5 (permalink)
Do you have any maintenance history on your truck? Has the injection pump, lift pump, or the injectors been changed at any time? I would suggest changing the return lines now and see if that helps. If it doesn't help, then we look to other possibilities. You can purchase the return line kit online at www.dieselpage.com It's about $25. Tim
You can try pouring some Power Service, Stanadyne or Marvel Mystery Oil in the fuel tanks. Pour a good amount in. Double or triple the amount recommended.
Old 08-16-2005, 04:37 PM   #6 (permalink)
gotmustang's Avatar
Marvel Mystery Oil in the fuel?does that work good?i dont know any of the history on this truck,just hate the smoke,some guys was telling me that this kind of motor just smoke alot saying all the 7.3 international just smoke alot
Old 08-16-2005, 06:18 PM   #7 (permalink)
My Photos: (24)
My 7.3l never smocked until the ip was turned up. No white or black smocke.
Now after the turbo and ip IT really DOES [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
If it is white smocke it could very well be air on the fuel system as the guys have been saying.
Exekiel.
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 08-16-2005, 10:34 PM   #8 (permalink)
Buy a quart of the Marvel Mystery Oil and dump it into both of your tanks. If that doesn't clear up the smoke, buy the return line kit.
Old 08-18-2005, 03:01 AM   #9 (permalink)
I have a 6.9 and a 7.3 and the 6.9 smokes quite a bit. I had the timing set and the smoke was reduced somewhat. I know the pump is turned up, because I replaced the IP and had it turned up with the rebuild when I installed an old style banks turbo. I think it smokes mostly because of the turned up fuel injection pump. It takes a second or two for the boost to build and use all that fuel, causing smoke in the interim.
If the body was not a rust bucket, this would be my favorite truck. I still drive it often and it is a great truck.
hweaver
1990 F-350 7.3 Crew Cab Banks Sidewinder Turbo E4OD 4X4,
1984 F-250 6.9 4X4 4Speed Old Style Banks Turbo (gave to daughter, but still in family)
1988 F-250 7.3 4X4, C-6 Auto, Banks Sidewinder Turbo
hweaver is offline
