I have 1994 F350 7.3 turbo IDI, E4OD, and I'm looking for a flex plate. Local dealer doesn't go back that far anymore. Can't even find any auto stores that list this item. Any help would be greatly appreciated. I am located in northern New Jersey.
00000give Brian a call at BTS. The number is 870-422-3673. They build the best E4OD trans out there. I have 2000 miles on mine and its great. They have any flexplate you will need. They are located in Leadhill Arkansas.
Found one at Badger Truck in Milwaukee 414-344-9500. I was refered to him by the parts guy at Bob Utter Ford (fordpartsonline.com). Several of the online places showed the part in stock, but when I called they were out and claimed the part was discontinued, and wished me good luck. Several others were closed due to the holiday. W
you pay shipping you can have mine come off an 1994 IDI turboed.
92 F-250 with luk clutch, got 304,000 miles out of old motor, now have IDI out of a 94 With factory turbo. Bought and installed ATS Exhuast housing, wastegate, downpipe. Turned up pump electric fuel pump. Runs like a bat out of hell.
