Old 09-01-2007, 10:22 PM   #1 (permalink)
Need help!!!
Hi guys,
I have a 89 ford tow truck (flatbed) and I'm having problems with it. I was on my way to pick up some cars and the truck just accelerate like crazy and I couldn't bring back to normal idle, I stopped her using 5th gear.
Now the truck starts really missing and with smoke from exhaust, If I leave it alone, it would stay idle but missing and some knocking but once I press gas pedal the rpm goes up like crazy and the only way to shut it down is by putting into gear.
I replaced the pump on top I guess it's called injector pump and still same issue. I've noticed in the exhaust there is either oil or fuel ( I cannot tell) and also on the passenger side underneath there was oil or fuel leaking on top of the exhaust.
What it could be the problem this time???
Please help!!!
estirpe is offline
Old 09-01-2007, 10:30 PM   #2 (permalink)
Re: Need help!!!
Also I forgot, the engine light is on and the oil indicator is crazy moving all over the place but if I press the gas a little it will go away and the oil gauge will stabilize
estirpe is offline
Old 09-01-2007, 10:57 PM   #3 (permalink)
arthurgoboom's Avatar
Re: Need help!!!
Maybe it is sucking oil up into the intake through the CDR, or maybe the lift pump down on the side of the block is leaking diesel into the oilpan and it's sucking that up through the intake. I'd check your air filter and intake for obstructions/mouse nests/rags forgotten, and check the oil to make sure it's not overfull. Either thing can make it more likely to push oil mist up through the CDR and the engine will burn it.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Beru ZD1A glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 09-01-2007, 11:55 PM   #4 (permalink)
Re: Need help!!!
Did you replace the pump or have it rebuilt? There is a wrong way to put a cover back on that will cause a runaway. It HAS to be the pump, else it would run away without you pressing the throttle.
My thoughts: "Now the truck starts really missing and with smoke from exhaust," Running rich, injection pump "I press gas pedal the rpm goes up like crazy" once again, injection pump "I've noticed in the exhaust there is either oil or fuel" If it is unburnt fuel, running very rich, injection pump. "passenger side underneath there was oil or fuel leaking on top of the exhaust." unrelated leak.
All advice worth what you paid for it, hope you get back to making a dollar with your truck soon. Good luck!
A.K.A. Sign_man
1988 F-Superduty bucket truck, 7.3 IDI, LuK Clutch, 5 spd, 4.10 rear
http://photos.thedieselstop.com/show...=70062&thumb=1
Phillipmc1268 is offline
Old 09-02-2007, 10:12 AM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Need help!!!
Check my gallery for the pic of the injector line attachment to the IP..... ensure there are no lines in the wrong place. The fuel pump and oil level checks are vgood suggestions....
Also check the accellerator cable that the return springs have full tension, there is on occasion a broken slide (red) on the end of the cable that can jam.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 09-02-2007, 06:03 PM   #6 (permalink)
Re: Need help!!!
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: cdnsarguy</div><div class="ubbcode-body">Check my gallery for the pic of the injector line attachment to the IP..... ensure there are no lines in the wrong place. The fuel pump and oil level checks are vgood suggestions....
Also check the accellerator cable that the return springs have full tension, there is on occasion a broken slide (red) on the end of the cable that can jam. </div></div>
You were right, the red part of the cable was broken, thanks a lot, I replaced it and that part is fixed, now the smoke still coming out thru exhaust, sometimes less but always there, you think I need new injectors???, I still hear some knocking like when too much fuel is been delivered...
Also the engine light is on until I press the gas and the oil needle goes crazy until I press the gas, you know where the oil pump is???
estirpe is offline
Old 09-02-2007, 06:07 PM   #7 (permalink)
Re: Need help!!!
I found where the oil pump is in your gallery, genius idea
estirpe is offline
Old 09-02-2007, 11:34 PM   #8 (permalink)
Re: Need help!!!
When you replaced your IP, did you pull the timing gear and case off? If you did, maybe your timing is off a tooth or two.
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
GOTTA LOVE FORD MUSCLE
Cjhstang is online now
Old 09-03-2007, 07:06 PM   #9 (permalink)
Re: Need help!!!
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Cjhstang</div><div class="ubbcode-body">When you replaced your IP, did you pull the timing gear and case off? If you did, maybe your timing is off a tooth or two. </div></div>
No, I aligned the gear pin with a mark I made and just pull out the pump with the lines and all..
estirpe is offline
Old 09-03-2007, 07:10 PM   #10 (permalink)
Re: Need help!!!
Also just for the heck of it I disconnected the source line (fuel) and attached a gallon of fuel just to see if it was bad diesel and the smoke was almost gone, I did this after my friend who works for uhaul told me that he added a quart of engine oil to the fuel tank apparently to clean the injectors, don't know if is true or not.
estirpe is offline
Old 09-03-2007, 08:51 PM   #11 (permalink)
Re: Need help!!!
a qt of oil to clean the injectors?????? that was brilliant--as it will do nothing---stanadyne makes stuff you can add to the tank--and it will clean the injectors--that oil he put in will make it smoke--
94_turbo is offline
Old 09-03-2007, 09:08 PM   #12 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Need help!!!
I think you found the problem estirpe ...friends with little or no knowledge of how to treat a diesel. The oil would cause excess engine speed and be hard to shut down due to it burns hotter than diesel does. Best to drain the tank with the oil and stroke that up to a lesson learned.......
Old 09-04-2007, 09:58 PM   #13 (permalink)
Re: Need help!!!
I drained the fuel and put new fuel in, changed injectors still smoking. any more ideas??
estirpe is offline
Old 09-04-2007, 11:36 PM   #14 (permalink)
Re: Need help!!!
You probably still have oil in the injection pump. How long did you let it run?
Old 09-05-2007, 08:19 AM   #15 (permalink)
Re: Need help!!!
I ran it for 15 minutes and then drove for another 15
estirpe is offline
Locate Ford Dealerships to find a new Ford for
