Old 09-21-2006, 08:11 AM   #1 (permalink)
need help glow plug relay
93 f250 7.3 l idi, my glow plug relay quit working on me. would not click anymore without hitting the side of it. I replaced relay with the bottom part also that has the wires going to the relay. now my lights do not go dim when i turn the key on like it use too. also the wait to start light comes on and goes off immediately. The relay cycles every time, and i checked the wires at the two glow plugs near the front and the voltage is cycling. But something is not right. i have to let it cycle like 7 or 8 times. where before it was only 2. i don't know what to check.
please help guys.
gbeach is offline
Old 09-21-2006, 01:07 PM   #2 (permalink)
Re: need help glow plug relay
Greetings, and welcome to thedieselstop !
First I would check the ground cable from the relay control, make sure it is clean and tight.
Second, I would test each glow plug. A few bad gp's will shorten the cycle time enough that the rest won't heat up enough.
On edit, also make sure your glow plugs are Motorcraft/Beru. Champions and Autolites don't last to long, and can swell up causing the tip to breakoff upon removal, very bad for engine.
1994 F250 7.3 IDI Factory turbo 5 speed Banks kit
9ENGEL is offline
Old 09-21-2006, 02:01 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
If you want wiring and test info PM me an email addy.....
Please be so kind as to put much needed info in your signature, go to "My Home" at the top of the page then "Personal info" click "Edit" put "all known" particulars for your truck/van in the signature block, any other info you feel worthwhile in other parts of this area. Fill in the "geographic location" too it is just as important, members can then direct you to the best known suppliers for parts, repairs, fuel etc closest you by location/ area/country. You could be just around the corner from a member willing to assist you or a parts store with what you need..
THANK YOU
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 09-21-2006, 02:40 PM   #4 (permalink)
i'll check the ground. I am ruling out the glow plugs, because they
were working the day before i changed relay.
thanks for reply
gbeach is offline
Old 09-21-2006, 04:16 PM   #5 (permalink)
tried grounding with another cable
did not fix anything
gbeach is offline
Old 09-21-2006, 08:26 PM   #6 (permalink)
http://www.autozone.com/servlet/UiBroker...23d800a3a41.jsp wiring diagrams
Also possible the fusible links blew out if the bi Yellow wires touched ground. It happens
Jamie
Currently resurrecting a dead '94 CC 7.3T 5 speed with a 6.9 and ATS turbo setup.
1989 F450 7.3 N/A 5 speed wrecker with 5.13's. Removing the bubble gum and tape to fix it correctly...
1986 C30 Crew cab 4 sp 'Frankentruck' Cut it in half and welded on another 1 ton frame and then added a rollback setup. 30'6" monster
ranchero50 is offline
Old 09-21-2006, 08:54 PM   #7 (permalink)
How is it that you "know" the GP's were working?
I suggest you check for continuity through all GP's, separate fact from feelings!
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 09-22-2006, 07:47 AM   #8 (permalink)
I have to agree with BuilderBob, check the glowplugs. You might have gotten a power spike and burnt out a few.
Jim
<font color="blue">[b]93-F250 (Super Duty), Extended cab, Long Bed, XLT, Gray & Black, 7.3L, New Injector Pump, New Injectors 4X4, ZF5 5 speed trany, 4.10 gears Limted Slip.</font>
<font color="red"> Click here to check out My $800 Texas Truck</font>
<font color="green"> My 30 ft Wilderness 5th wheeler after new paint job and striping.</font>
<font color="purple"> The 2004 IDI rally in July</font>
<font color="red">Life, Liberty and the Pursuit of All Who Threaten It </font>
ltl_jrw is offline
Old 09-22-2006, 08:08 AM   #9 (permalink)
Ranchero50, where are the fusible links located at. I have checked and have voltage going to all of the plugs, but how do you check the glow plug without taking it out. I have heard nightmares about the tips breaking off
gbeach is offline
Old 09-22-2006, 09:23 AM   #10 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Check my gallery for the 7.3 GP system info.
Old 09-22-2006, 09:30 AM   #11 (permalink)
thanks for the info
that really helps
i will check glow plugs this weekend
maybe the new relay was providing to much current and burnt some up
because my old one the terminal actually broke off, and when i put the new one on it did dim the cab lights the first time i turned key on then never again. I'll check with a meter .
thanks again
gbeach is offline
Old 09-25-2006, 10:18 PM   #12 (permalink)
5 bad glow plugs. now the fun and prayers begin. they are the originals with 160k on them
gbeach is offline
Old 09-26-2006, 01:23 PM   #13 (permalink)
cdnsarguy's Avatar
My Photos: (66)
If they are Beru then you may be lucky, carbon may be a problem though. So do the TDC trick for the pistons.........
Old 09-26-2006, 09:02 PM   #14 (permalink)
what is the top dead center trick. I have not read about that. Is beru Motorcraft. I priced today at international dealer he said they were international brand $18
at autozone motorcraft 8.99
is the tip metallic
I can't screw this up.
I am visiting both tomorrow.
gbeach is offline
Old 09-29-2006, 12:58 PM   #15 (permalink)
fixed.
replaced all 5 bad glow plugs. everything back to normal. really drawing some current now. must have had some bad to begin with and didn't know it. they were the beru, all came out easy.
thanks for everyones help
gbeach is offline
