Old 02-26-2006, 02:27 PM   #1 (permalink)
Need info on 94 to the 97 F250 7.3L
I need advice on what year model from the 94 to the 97 F250 7.3L trucks were the most trouble free. I don't want any "Fly by Wire" Computer crap.
My reason is that I'm really not legal pulling my 26'+ Weekend Warrior Toy Hauler with a GVWR of 11,100 lbs. Are the 94 to the 97 F250 7.3Ls legally able to pull 11,100 lbs on a trailer hitch and what is the max hitch ball weight?
I didn't post this to the other 94-97 Forum yet as I know some of you have these years and want your opinions.
Jim Larsen
2000 F250 SD Lariat, SC, SB, 4x4, 7.3L PSD, 6-Spd ZF, 8,800 GVWR, 20,000 GCVW, Reese Class-V Tow Beast Receiver Hitch, Prodigy V2.6, 4" MBRP Stainless Steel Exhaust, AIS Induction Air Filter, AutoEnginuity
2002 26' FT2200 Weekend Warrior Toy Hauler, 102" Wide-Body, 11,100 GVWR, Reese Titan 14,000 lb Trunnion Heavy Duty WD Hitch, DC HP Sway Ctrl, Onan 4BGE-P Emerald Plus GenSet
jlrsn is offline
Old 02-26-2006, 03:01 PM   #2 (permalink)
Re: Need info on 94 to the 97 F250 7.3L
You have come to the right part of town, if you want "No Computers".
1994 was a split year, some are good, some are Power Strokes. After that, it was down hill, so to speak.
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 02-26-2006, 04:23 PM   #3 (permalink)
Believer45's Avatar
My Photos: (16)
95-97 were all Power Strokes. In 94 there were three engines available - 7.3 non-turbo, 7.3 turbo indirect injected and 7.3 PowerStroke. Both the IDI turbo and the PowerStroke were badged as TURBO DIESEL, the PowerStroke badges did not come out until 1995.
In 94 the PowerStroke was only available with a manual transmission so if you are looking for an auto you can look at any 94 turbo diesel or 94 non-turbo. If you are looking for a hand shaker you will have to verify PowerStroke vs IDI.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Believer45 is online now
Old 02-26-2006, 05:50 PM   #4 (permalink)
Were the first Powerstrokes all computerized or partially.
jlrsn is offline
Old 02-26-2006, 05:53 PM   #5 (permalink)
I want a ZF Transmission anyway. I can always add a turbo on an IDI. What are the tow weights?
Jim Larsen
jlrsn is offline
Old 02-26-2006, 06:02 PM   #6 (permalink)
well i know i bought my 94 idi turbo with the 5 speed and she has some low pulling 1st and 2nd, gears, mine is also a 4x4 with 4:10 gears, and if the book is right there is not that much difference between the HP on the powerstroke and the IDI turbo of that year,
1994 f250 super duty ext. cab 7.3l IDI turbo. 4x4 manual tranny. I am new to the diesel trucks, i bought this truck to pull my tractor and equipment for my landscaping business
ncfirefighter46 is offline
Old 02-27-2006, 12:44 AM   #7 (permalink)
Any 94 powerstroke I have been around has been one hard runner of a truck...ANY...that is when they are unloaded. As far as I am concerned, a stock IDI will outpull a stock powerstroke any day, so the horsepower differences are basically assinine. The GVRW is the same on the size of truck no matter the engine. Isnt it just what the truck will physically have enough size for? The DOT could care less about how much brute power you have to pull it, as long as it is legally in your weight specs of the frame and chassis.
Shawn
Custom farming in NWIA.
tractors:
706,806,1206,1256,5288,7140mfd.
vehicles:
-1985 Ford F250 reg. cab,blue w/ extra clearance lights,4x4,T19 4 gear,3.55's,Banks sidewinder w/ K&N, 3.5" straight pipe, 2 gauge pillar, and 3 below dash. Pioneer cd player & a pair of 12" RocFos subs shoved behind seat. Old school tuned Midland 23 channel CB w/ PA and 13 foot whip antenna, Solara DSC marine-band and 4 foot midland antenna hooked too a Delta diamond plate tool box, Aluminum rims,hide-a-ball, RoadMaster drop rear bumper,air gate, and stainless stick on's on the bottom body line.
-93 Ford F250 7.3L IDI Turbo Diesel, ATS upgrades, 4" exhaust and 5" stainless tip, 5 speed, 4wd, 3.55's, maroon on silver, American Racing rims, custom built air gate, DMI rear bumper, extra clearance lights.
-61 Ford Falcon Futura, 289HIPO, T10 4 speed, 9" rear w/ cleveland locker and 3.55's, linelok, Granada front discs.
Mosin Nagant's, K98's, K-31's, Enfields, AK's, and SKS's.
twelve0six is offline
Old 02-27-2006, 09:17 PM   #8 (permalink)
PSDfreak's Avatar
The first powerstrokes are just as computerized as the '97;s...difference electronic wise is the PCM's in the 94.5's and the '95s are flashed with OBD I diagnotics instead of the OBD II that we see and use today.
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 02-28-2006, 12:32 AM   #9 (permalink)
Thanks Casey,
That is important for me to know. I dislike OBDI as it gives very little data. If it's going to be computerized an OBDII Reader or Browser will take the guesswork out of troubleshooting. I have a full OBDII Browser that I use on my and my family's cars/trucks except for my youngest son who has a new Jeep Grand Cherokee that has OBDIII.
I want to thank everyone who answered my quest for knowledge.
Jim Larsen
jlrsn is offline
Old 02-28-2006, 01:48 PM   #10 (permalink)
The reason the OBDI diesn't do anything on the idi manual tranny is that there is pretty much nothing for it to do. You may also want to look at 350 duallys. I think you should be legal pulling that, you'll need the right licence on the truck and probably a class 5 hitch.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 02-28-2006, 11:56 PM   #11 (permalink)
I've been looking for F350s also but I haven't found any with low mileage or in the western states.
Jim
jlrsn is offline
Old 03-01-2006, 10:56 PM   #12 (permalink)
I know there's some diesel duallies for sale down here in the LA area. Look on autotrader.com and use an LA zip (90041 is NE LA, 91105 is me here in Pasadena).
1993 F250 4x4 supercab, 7.3 NA, E40D, 3.55s---now deceased, mashed and totalled by a drunk driver---much cheaper to just "run what ya brung" than to buy new.
k2bronco is offline
