Need Wire Info. for Trailer Brakes - Diesel Forum - TheDieselStop.com
Old 07-11-2009, 06:27 PM   #1 (permalink)
66hybrid's Avatar
1. My 1993 F250 has the four prong quick plug under the dash
2. The power distribution center on the inner fender has fuses for trailer brakes and battery charging.
3. The truck has a very hefty 4" reciever
There is no 4 or 7 prong plug in the rear! Everything looks original and nothing has been spliced. The OEM harness has five wires. None of the five look like the trailer brake or charging wire. Where are they? I assume they are somewhere since the distribution center has them listed and fused.
1993 F250 IDI, EO4D, Regular Cab
1977 F150 , 4x4, long bed, 351M
1961 F100, Unibody, 292, Column shift w/OD cable
Marshall University Alumni, Go Herd!
66hybrid is offline
Old 07-11-2009, 06:46 PM   #2 (permalink)
chuckster57's Avatar
My prodigy has a four wire harness on it. I don't remember how it's hooked up but if you go to tekonsha.com you can down load the wiring diagrams. IIRC the wires are universal in coding. As far as the plug at the back of the truck, It may not have ever been put in. You can look under the bed for a harness that terminates near the bumper. My '86 had the harness and I had to add the plug and wires.
Trailer Wiring Diagrams
Here is where you can see the different plugs and the schematics. Hope this helps
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
