new aftermaket heads7.3 - Diesel Forum - TheDieselStop.com
Old 03-01-2009, 01:49 PM   #1 (permalink)
sootieoil's Avatar
I bought a set of cylinder heads for my 7.3 and realized the intake ports are considerably much smaller than my original 6.9/7.3 heads.
The intake manifold is much larger than the ports and it will need much porting to make match.
The exhaust port and bowl looks the same as original I wonder wht the intake was cast smaller anyone have anything to add?
I will post pics soon
to buy Amsoil please contact TDS Amsoil site Sponsor DieselManor,Dieselsite,
sootieoil is offline
Old 03-01-2009, 07:31 PM   #2 (permalink)
DaytonaBill's Avatar
Where did you get them from?
1992.5 F-350 IDI crew cab with 4 wheel drive, fresh E4OD, long bed with dual tanks. 22 MPG at 70 MPH, 15.5 MPG at 85 MPH with A/C running!!!
Mat 22:37 Jesus said to him, Thou shalt love the Lord thy God with all thy heart, and with all thy soul, and with all thy mind.
Mat 22:38 This is the first and great commandment.
Mat 22:39 And the second is like it, Thou shalt love thy neighbor as thyself.
Mat 22:40 On these two commandments hang all the law and the prophets.
DaytonaBill is offline
Old 03-04-2009, 12:00 PM   #3 (permalink)
sootieoil's Avatar
Alabama cylinder head? CHINA? who knows? I really dont know where these heads were cast.
Old 03-04-2009, 12:14 PM   #4 (permalink)
sootieoil's Avatar
here is a few pictures that have nothing to do with IDI heads enjoy!
Like the mustang? it is a 3/4 scale.
new aftermaket heads7.3-feb1409-002.jpg   new aftermaket heads7.3-javier-001.jpg   new aftermaket heads7.3-javier-357.jpg   new aftermaket heads7.3-javier-267.jpg
Old 03-04-2009, 01:32 PM   #5 (permalink)
Bill1013's Avatar
Enter 1988 and the completion of a totally new truck with the introduction of Navistar’s new 7.3 liter ID!
diesel engine. Although not revolutionary, there are many improvements that accompanied the introduction of
the new engine.
The 7.3 now used select fit pistons at the manufacturer. The pistons were stamped with A, 6, C, and D and
had to coincide with the letter stamped at the base of the cylinder bore. Replacement pistons were stamped
with an S. New plateau honing procedures accompanied the select fit pistons for better ring seating and
engine break-in. Also the lower rear corner coolant passages at the head mating surface were blocked to
coincide with plugged coolant passages on the heads. This was an effort to reduce coolant seepage during
cold start and warm-up.
Most of the changes were made to the heads, making them not interchangeable between the 6.9 and 7.3. The
precombustion chamber volume was increased to 20.42 cubic cm for emissions certification. Even though the
pre-cup chamber inserts are physically interchangeable, the throat was re-designed and an “88’ stamped on
the 7.3’s to distinguish them. The glow plugs were now off-center and the injection nozzles retracted .060” for
emissions. The injector lines were also now .060” shorter to coincide with the injector retraction. However,
this is negligible and the injector lines are still interchangeable between the two engines. The new 7.3 valve
stem shields are larger to reduce emissions and both intake and exhaust shields are now color coded, though
they are interchangeable. Also the 7.3 exhaust valve metallurgy has been changed, increasing the nickel,
chrome, and silver content while reducing the manganese content. This makes the 7.3 valves usable in a 6.9,
but not the other way around. The gasket cutouts between cylinders were eliminated to prevent cosmetic
corrosion and improved viton oil drain back seals were added to the gaskets. The 7.3 also used a new
embossed front cover to aid in gasket sealing and eliminate water pump replacement due to seepage.
Specifications for the 7.3 are as follows.
Max HP 185 © 3300 RPM
Max torque 338 ft/lb © 1800 RPM
Cylinder bore 4.11”
Stroke 4.18”
Displacement 7.3 liters or 444 cubic inches
Comp ratio 21.5:1
Top deck thickness .560”
Oil drain back holes 7/16”
Cylinder head bolts ½’ -13 UNC 6” long
Head bolt washers .134” thick
Head bolt torque lOOft/Ibs new or used
Head gasket fire ring ID 4.22”
Glow plugs off center in pre-cup
Pre-combustion chamber volume 20.42 cubic cm
This might help in determining if you have the right heads, hope they didn't send you 6.9 heads.
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 03-11-2009, 10:57 PM   #6 (permalink)
sootieoil's Avatar
7.3 turbo
ok here are some head pics I will post better pics of actual sizes aftermarket and oem port sizes
new aftermaket heads7.3-feb1409-037.jpg   new aftermaket heads7.3-feb1409-106.jpg   new aftermaket heads7.3-feb1409-102.jpg   new aftermaket heads7.3-feb1409-107.jpg
Old 03-17-2009, 09:05 PM   #7 (permalink)
Did you get those from Alabama Cylinder Head?
Old 11-24-2009, 03:09 AM   #8 (permalink)
sootieoil's Avatar
I bought these from alabama most likely, I ported them also, easy job, took about 2 hrs tops taking it easy, intake ports opened up nicely, I just matched the openings, the rest of the port I left untouched, nothing I can do to the casting to improve it, still need a set of stellite valves, and some head gaskets, I was searching on here head gaskets solutions, wish Cometics would make us some gaskets and found my old post, so I updated.
Javier
Old 03-04-2011, 11:31 AM   #9 (permalink)
Looks like these heads are not such a good deal.
I have collected a ticky tick tick tick, first time I got the engine good and hot.
So I have done checking and decided the pass head is coming off.
I get compression readings all over the place on one cylinder.
180psi one time then 30psi then 0 psi
I think the exhaust seat fell out the register and makes the tick tick tick noise I cant put a finger on.
Will have pictures of this in a couple days.
Only 8000 miles on the engine, now I have to open it up...
Javier
1988 F250 dually 7.3 IDI Banks Sidewinder C-6 with GearVendors overdrive 3.55 ring gear
Amsoil 5w30HDD with full flow / bypass filters,
Evans coolant and Amsoil conical air filter.
AMSOIL ATF in the transmission, AMSOIL gear oil in the diff.
20MPG city 25/28 hwy
IDIABUSE is offline
Old 03-04-2011, 12:47 PM   #10 (permalink)
cdnsarguy's Avatar
My Photos: (109)
When ordering heads from any source always quote the head casting number in between the two middle valves.......IE 1609030 03 which is on my 93 7.3 heads.
Proud Canadian BOOB man too!!
cdnsarguy is offline
