Re: New I.P. now truck won't start
check to see that you have 12 volts and hear a clicking when you connect and diconnect you fss. if you have 12 volts and dont hear a click bad ip. if you dont have 12 volts dissconect the fss and run an aligator clip from the battery to the fss and see what happens. are you sure you have all the right plugs in the right spots? just checkin!
do you have fuel going through the ip supply line?-fuel filter to ip?
hope this helps post back and lets us know.
-Jeremy Roooster! [img]/ubbthreads/images/graemlins/tongue.gif[/img]
American by birth, Southern by the grace of God!
1991 F250 7.3l 200XXX extended cab long bed. 3.55's REDNECKED OUT!! 295/75/16 Bfg All Terrains 16 in billet rims. New front brake pads and rotors, rear shoes, glow plug controller, glow plugs, return line kit duralast batteries, mitubishi off set gear redution starter, altenator, valve cover seals, holley red pump,new injector pump, soon to be new injectors, new vacum pump. Removed soup bowl and drilled holes in air intake.
http://community.webshots.com/user/r0oster06
