Old 08-01-2005, 11:23 AM   #1 (permalink)
New injectors with pump?
I've been nursing a sick injector pump for a long time now but haven't replaced it because of lack of time and money. Now a big oil leak requires work so I guess it would be silly to gain access to the valve covers without doing the IP job while I'm at it. I'm trying to save as much money as possible. Is it silly to not replace the injectors and return lines while I'm at it? I'm just about to hit 200K. Naturally this all comes about right after ordering 4 new tires!
Thanks, Brad
'93 F250 Factory Turbo, straight pipe, 5-speed, 4x4, Super cab, Long bed, 200,000 mi. Dual booster seats and french fries on the floor.
'55 F750 Big Job, 4WD, 5-speed, 317 V8, big ol' bright orange beast.
'70 F250 "The Stegesaurus", 4wd, 4-speed, seized 390, parked at the ranch until.........
snowturtle is offline
Old 08-01-2005, 11:49 AM   #2 (permalink)
Re: New injectors with pump?
i just ordered a new pump from ken and asked him this very same question...as long as you have no return line leaks and no other signs of bad injectors (knocks, etc) you will be fine just keep in mind that these items both have about a 100,000 life and are usually serviced together, and anytime you do the injectors you have to do return lines or you will probably spring a bunch of leaks...bottom line you will be fine and when/if you decide to do injectors also you gain even more power! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1989 F-250: supercab, long bed, 4x4, 5 speed,3.55's up front and rear, turned up pump,Pyro ofcourse!, custom stack, homemade lpg fumigation, more too come...At CSU, the black beauty is for sale...
nickbf2504x4 is offline
Old 08-01-2005, 02:58 PM   #3 (permalink)
My Photos: (23)
Usually, I change injectors when I change the IP. The old injectors will be tired, and open more easily (sooner) than the they did with the older tired pump. A new pump with old injectors is a rough combination. But I trust Ken's advice also. He's played with it all more than I have. At the very least, I'd have the old injectors tested.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 08-01-2005, 11:47 PM   #4 (permalink)
Your going to have to take the lines from the pump to the injectors loose anyway so it will take you another 20 minutes to change the injectors. I've had at least 5 sets of injectors tested in the last 3 months or so. Out of all those injectors which I thought a lot of them should be good. I ended up with 1 set. The bad ones had no spray pattern, just a stream. A lot of them had less than 100,000 miles. At 2.30 for diesel fuel it won't take long to pay for a set of injectors.
Greg
1988 F250 7.3 diesel 4x4 auto C6 now ZF5
1990 F250 7.3 diesel 4x4 auto E4OD. now ZF5
1992 F250 7.3 diesel 4x4 ZF5
Greg77 is offline
