Re: New Rear End For 92 F350
Good point Squid63, and to add to that fact, the yokes are not interchangable if the u-joints are different. They are of different length. If you need the newer style yoke or any other parts like 4.10 gears I could pull them off the axle I took out of my truck.
Where are you located?
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
