Well, truck was running great... took off the valve covers and put new seals on them. Removed the fuel injection pump, fuel lines(to the injectors, and fuel filter(replaced with new). Put new seals on the piece that the injection pump mounts to. Put it all back on and intelligently forgot to tighten the bolts from the injector lines to the injectors.
Let the seals dry over night, used engine degreaser, (put suran rap and rubber band around intake) and rinsed it off.
Tried to fire it up, realized i didn't tighten injector lines, took care of that, tried again... nothing.
gave it a shot of ether while someone cranked it = major smoke out of intake and exhaust.
put a clothe soaked in diesel over intake, truck fired up then shut down...
Checked the bleader valve, fuel was there. Injector pump does have the 'click' when key is turned.
One thing i did notice... can't remember if its normal, but the 'water in fuel' light comes on (very dim) when i crank the engine.
The intake manifold still has a small puddle of water/degreaser sitting on it in injector pump area...
Well don't think i missed anything. Need to try n get her running for memorial day. Any ideas! Thanks guys!!!!
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
Is there an out of line? Your talking about the gear that is housed by thing you fill it with oil with right? How do you know if they're lined up correctly??
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
[/ QUOTE ] Then why'd you go messin' with it... J/K Fix it til it's broke.....
[/ QUOTE ] Did you loosen/ remove that cover? If not, don't worry about it. If so, Zigg has got a write up on fixing the timing mark alignment.
Work like there is a tomorrow and play like there isn't.
87 F250 Lariat SC LB 4X4 with an NA 6.9, C6 and 4.10's. Dana 50 IFS up front. 244K mi. 3" exhaust, WVO, Ram air. Thinking about propane or methanol/ water...
First diesel and a lot to learn....
96 F350 CC LB 4X4 AT 231K
Second diesel and still a lot to learn...
That isnt the same injection pump that he is talking about on his site. That is for a 6.9, they must have changed the pump cause the pics and some of the stuff he's explaining doesn't match up...
Anyone have a right up on adjusting the injection pump alignment on a 7.3?
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
Ok, forget the last post. It is the same injection pump, but that write up is only about turning up the fuel, not aligning the timing gear with the engine. Does anyone know what to do? (or if i have to remove the injection pump again) how i know if the gears are aligned correctly?
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
Not sure why Zigg's article isn't linked on his home page, but a quick search popped it up.
Best of luck,
Devo
that is perfect!!! yeah, i was looking up his homepage and thought that was what you were talking about. Thanks alot for your help!
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
Ok, followed that write up exactly. had the damper lines lined up, the timing gear lined up and set in place... Made sure it was on the compression stroke (it was difficult to turn and i could hear the air compression escaping. still no start. I was finally able to fire it up on a small shot of ether and the gas peddle down. but as soon as i got off the gas she stalled. (i may have had the spring on the throttle control set at the wrong spot--donno if that would do it). reset that tried again and batteries started to go. They charging now...
Any ideas??
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
OK so you have the timing lined up on the IP to Housing...try advancing it 1/8 inch.. IE turn the IP to the pax side 1/8 inch..tighten nuts and try again. YOU did align the "Ys" on the cam gear and the timing gear right....... with the engine at TDC....
Ok, I guess I was not on a compression stroke... I finally got it fired up but like the write up link listed above says - if its set up on an exhaust stroke then it will smoke like crazy, no power, and a pain in the --- to start. Well all symptoms were there.
I could have sworn it was on compression tho... it was getting pritty tough to turn the crank and i could hear air escaping as i turned it...
Thanks for the ideas guys....
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
Got her started and ran it down the road to get all the fuel outa the cylinders and what not... still smokes, not white anymore, now its blue. Idles rough, esp at first start up then gets a little better. also seems to have problems once it gets to 2000rpms when driving...
Is this all fine tuning stuff or am i off i tooth?? (I was very careful about lining it up)--will it even start when its off by a tooth?
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
If you were still 180 off this would probably be of more help, but...
I just looked at the 6.9 I'm rebuilding, and of course I was able to line up all the gears prior to replacing the front cover. With everything lined up, and the engine sitting at TDC, the dowel pin on the IP gear sits at about 4 o'clock. Your's might be different, but it shouldn't be...
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
