Old 01-29-2006, 05:55 PM   #1 (permalink)
No fluid out of rear brake lines???
I'm doing a brake job on my 94 F250, I have the rear pasenger cylinder off. I tried hitting the brakes to push some fluid out of the line to clean out some dirt but nothing comes out, no matter how hard I push the pedal. I am doing this with the truck off since it is on 4 jackstands, does this have something to do with the anti-lock brakes? Only the back are anti-lock right? The front calipers are applying just fine but nothing will come out the open line in the back.
thanks,
-Rob
'94 F250 XLT 7.3L. Turbo Diesel 4X4 "OFF ROAD" package, X-Cab, 4.10 grears, Now a 5 speed, original IP, just did injectors,"Wallace mod" 3.5" turbo outlet housing and 3.5" DP and straight piped exhaust, 113K on the clock. Repainted it black. Ispro pyro and boost gauges, turned up pump.
ClassicFordGuy is offline
Old 01-29-2006, 07:28 PM   #2 (permalink)
Re: No fluid out of rear brake lines???
My 95 always bleeds engine off. Only the rears are anti lock. The anti lock valve is on the frame rail just about below the booster. There is a bleed screw on it. You could try opening that and see if fluid is reaching that point.
The Racer X Built E4OD THAT CAN Video. 1997 F-350 7.3 Twin Turboed Power Stroke Diesel. Fueled with 473 + cc's of Diesel and nitrous!
Family owned & sponsored by : FloridaNorth
For Fuel - D.J. @ DIY-injectors.com
"AMERICAN INGENUITY " Half of AMERICAN is I CAN."
Racer_X is offline
Old 01-29-2006, 10:15 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Could be a bad flexible rubber hose too, theu can over time cause flapper valve effect sometimes allowing fluid in and not back or what your experiencing........also check for flattened lines. Remove the rear brake line from the M/C, pump it and see if fluid comes out.
Note...... Brake fluid is harmfull to the paint.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 01-30-2006, 12:46 PM   #4 (permalink)
Thanks for the imput, I will look at it tonight. I didn't even think of a flatened line. I did check to see if the lines were even connected as the rear tires were burned off and I suspect the P/O was doing burnouts or something.
In the few times I did drive the truck around the block before it went in the backyard the ABS light was on, could the ABS Valve on the frame rail be locked up? I will check the bleed screw on the ABS valve, if fluid comes out there then I don't need to disconect the line at the master cylinder right?
Thanks,
-Rob
Old 01-31-2006, 12:50 PM   #5 (permalink)
Well I worked my way up to the master cylinder and all looked well except that no fluid was in any of the lines. I unbolted the rear line fromt the master cylinder and was shocked by what I found. The P/O had screwed a machine screw into the line then bolted it up again. Guess that's one way to avoid replacing rear pads and clylinders.
I assume this could cause the ABS light to come on? Should it go off again once it has fluid and begins working or is there a way to reset it?
Thanks for all the help,
-Rob
Old 01-31-2006, 02:47 PM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Any info re the RABs valve ops should be in the info I sent you........
Old 01-31-2006, 07:48 PM   #7 (permalink)
yes, it was full of diagnostic information that will be very helpfull now that the ABS modulator is actualy seeing some brake fluid.
Thanks for the info,
-Rob
Old 01-31-2006, 08:18 PM   #8 (permalink)
-Rob
Unbelieveable [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] If you were in the rust belt, I'd suspect someone would have done that if the rear line rusted out between dual tanks where it's hard to reach. Looks like you have it now.
Racer_X is offline
