Old 09-05-2006, 10:40 AM   #1 (permalink)
No more Wait to start or water in fule lights
I got the new Injector pump on and had a hard problem starting it. So I pluged in the block heater and about after 30min it started fine. blead the system of air. Truck start fine yesterday and this morning with no wait to start light.
before I had this problem I had a series of clicks with the voltage meter jumping around I could tell that this was comming from the GP controler.
On the way to work this morning I notice that the charge light was flickering on off on off, but the truck cranks and runs fine.
Could my GP controler have gone out?
I have almost got this bugger fixed please help shead some light on this if you can.
Thanks,
Chris.
1993 Ford F-250 Diesel 7.3L IDI, E40D Auto, 4x4, Super cab Long bed. Bone Stock with 254,000 miles on it. 2.5" lift from Tuff Country & Super Winch Lockout hubs
CBNASH is offline
Old 09-05-2006, 11:15 PM   #2 (permalink)
Re: No more Wait to start or water in fule lights
I'm not going to be much help but have a similar problem.
I had bad glow plugs, truck wouldn't start. Just replaced them all with motorcraft plugs and the number of clicks reduced from 20 to 6, but I still get the clicking!
Hope someone has an answer for you.
1990 F250 Extended Cab, 7.3L IDI, No turbo, Auto transmission, 215K miles, lots of rust!
1994 F250 Extended Cab, 7.3L IDI, Turbo, Auto transmission, 158K miles, very little rust
pigseye2 is offline
Old 09-06-2006, 01:07 AM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Nash I sent you a PM with some info.....visit my gallery for the GP system Pic. Check the wierd little connector on the back firewall to GP controller (pink and black wires) and see if it is connected. If it is check your fuses and bulb.
Depending on how cold the engine is will denote how long GPs stay on, unless some are burned out, then they will shorten the WTS light on time and clicking starts.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 09-06-2006, 12:04 PM   #4 (permalink)
im gonna have to watch this link because none of my lights come on when i turn the key on either, i do get the voltage gauge jumping around after a few moments and hear the clicking but no lights have came on since i have owned the truck. I did pull the dash and look at the bulbs, they all looked good. However i did put a test light to the wiring harness of the lights and only one wire was ever hot and it was constantly hot unless the key was turned off. I didnt ever get any of the rest of the wires hot like for just a second for a pre start bulb check. Hmm any thoughts?
93 extd. cab
7.3 IDI N/A. 4.10's 5spd
Warn hubs not to much else. Gonna try and make some bio diesel at some point. we will see what happens.
07.5 Dodge Quad Cab 4x4
6.7 Cummins, 68RFE
07 Ford F350 Tow boss
6.0, TQshift
Riddlerls1 is offline
Old 09-06-2006, 02:34 PM   #5 (permalink)
Both the WTS and WIF gets it's power from fuse #17. Something to check. Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 126K
tim94f250 is offline
Old 09-06-2006, 04:03 PM   #6 (permalink)
well i changed all the bulbs today even though they all looked good.
Now the WTS light comes on like it should but none of the other lights have come on when i turn on the ignition for a bulb check... should they? there is a engine temp light, a water in fuel light and a fuel filter light. are they supposed to come on for a bulb check?
93 extd. cab
6.7 Cummins, 68RFE
6.0, TQshift
