Old 07-30-2005, 09:29 PM   #1 (permalink)
no start
lower actuator rod broken hav'nt been able to get lower broken section out i can touch both ends & it slides up & down how does this !@##$$%%^^^^^%%$#@#@@ darn thing come out. i even took the .45 out & threatened it still no go help help help?
97 dodge 2500 4x4 cc lb 12V auto 3.54 pillar gauges 215 nozzels
31'TT at 8000 lbs
94 explorer
shorthair is offline
Old 07-31-2005, 01:07 AM   #2 (permalink)
My Photos: (17)
Re: no start
If you're talking about the actuator rod in the steering column, then you gotta start at the top and pull the steering wheel. Baja
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 07-31-2005, 02:46 AM   #3 (permalink)
Re: no start
steering wheel comes off, remove turn signal assembly, then when you get all the way in there, the broken metal piece will come out in two pieces, but the new one won't go in unless you remove the two side bolts with a special tool. I forget what the tool is called, but you can't do it without it.
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
Old 07-31-2005, 04:35 AM   #4 (permalink)
Re: no start
wheel is off turn signal out &amp; switch housing removed, plastic cover below out column retainer removed, 3 allen bolts removed from under tilt mech. onlt trim still there is the section that covers the button to release the key in normal operation.
31'TT at 8000 lbs
94 explorer
Old 07-31-2005, 10:58 AM   #5 (permalink)
Re: no start
Ok, the very last step is removing two metal threaded screw things, one on each side of the black steering housing. Takes a special tool that I borrowed from my very cool independent truck repair shop. Once those two screw things are removed, you slide the housing down, but not off! Just slide and tilt enough to remove and reinstall $10 metal tilt actuator part, then reverse install everything to finish. Make sure you remember to attach bottom end to the rod that goes to the ignition switch.
Hope this helps,
Hugh
Old 07-31-2005, 12:16 PM   #6 (permalink)
Re: no start
hugh d are you talking about 3 phillips screws coming in from the dash side of the column that i can see in a mirror.got screws out collar slid foward can slide broken shaft up till it hits on hinge? but still needs at least 3/8" more room to remove.
31'TT at 8000 lbs
94 explorer
Old 08-01-2005, 12:21 AM   #7 (permalink)
Re: no start
Nope, not the philips screws.
These two are threaded metal posts, one on each side (ie. driver and passenger sides), I think...it was 1.5 years ago that I did mine. Searching the archives gives me nothing, I'll keep trying to find the name of that tool.
How about "Shroud Retaining Screws". Any luck?
Old 08-01-2005, 02:43 PM   #8 (permalink)
Pivet Pin removal
Finally, it is called the Pivot Pin Remover. http://midwayautosupply.com/detailed...ption.asp?3615
$10-15 for tool
Removes the pivot pin on GM, Ford and Chrysler tilt and telescoping Saginaw steering columns. Includes an extra screw.
This is it!
Hugh [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Old 08-02-2005, 05:36 AM   #9 (permalink)
Re: Pivet Pin removal
hugh d
saw that do i drill &amp; tap the pin to pull it?
31'TT at 8000 lbs
94 explorer
Old 08-02-2005, 10:20 AM   #10 (permalink)
The removal tool threads inside the pivet pin, then you extract the pivet pin by twisting the bolt on the tool as the tool presses against the column and pulls out the pin (like picture). Once the two pins are removed, then you can tilt the column down another 1/2" or so and slide the new tilt actuator inside the column. Just slide the column housing enough to get it in, not anymore than you need to.
Realign the holes and push the pins back in after you are finished, no threads on the outside of the pin, just the inside.
Not difficult once you have the two pivet pins removed. Impossible without removing the two pivet pins.
--Hugh
Old 08-04-2005, 07:11 AM   #11 (permalink)
hugh d thanks for all your help she's back together &amp; runs.
you're right it could not be done without PIVOT PIN PULLER.
31'TT at 8000 lbs
94 explorer
Old 08-04-2005, 01:06 PM   #12 (permalink)
It is a pleasure to be able to help another TDS member get their truck back on the road. My diesel knowledge is limited to what I have learned since buying my first diesel truck a few years ago. Almost everyday that I visit TDS, I learn something new.
--Hugh [img]/ubbthreads/images/graemlins/smokin.gif[/img]
