Non-turbo IDI vs. PowerStroke vs. 460 gas? - Diesel Forum - TheDieselStop.com
post #1 of 28 (permalink) Old 11-22-2011, 10:22 AM Thread Starter
ShakeFreight2's Avatar
Question Non-turbo IDI vs. PowerStroke vs. 460 gas?
Hi Guys!
I'm glad I found this site, as I have a truck purchasing/ownership dilemma. Hopefully my ignorance does not get me flamed...I'm brand new to diesels, but a long time FORD lover.
I have found the truck of my dreams (not really, but in my price range) that I'm considering buying. It's a 92 F350 with 358k miles and from southern KY, so it is virtually rust free and in shockingly good condition body/frame wise.
My question concerns its 7.3 non-turbo engine. Is there a significant difference in performance, fuel mileage and longevity between the old IDI engines and the PowerStrokes? Can an OEM/aftermarket turbo be installed relatively inexpensively on the IDI, or should I continue looking for a newer PS equipped model?
Please don't laugh for asking this, but is a rebuilt 460 swap a straightforward enough process to be worth my while if the old engine is tired, or is that a cardinal sin if one already owns a diesel powered truck?
My dad had an identical truck with the 460, and hated the fuel mileage but loved the BB power. I wonder if the cost of repairing/maintaining an IDI or PS is worth any advantages held by the increased mpg? Seems to me, the horsepower and torque numbers for non-turbo IDI and 460 gas are virtually the same. So where are the "felt" differences.
Thanks for indulging me!
ShakeFreight2 is offline
post #2 of 28 (permalink) Old 11-22-2011, 10:45 AM
The 7.3 IDI is unbeatable for reliability, longevity, durability, and ease of repair. It's not a speed demon but I doubt it would ever leave you on the side of the road. Even if it does, as long as you have a simple set of tools you should be able to get going good enough to get to to the nearest service station.
1990 F250 Extended Cab 7.3 Non Turbo 280,000
erik49051 is offline
post #3 of 28 (permalink) Old 11-22-2011, 10:59 AM
jacksonguitars4life's Avatar
yep the old idi is a great engine and yes you can install a turbo. you may have to find a used one but the ats 088? (not sure) or banks sidewinders are specific to this engine as a powerstroke turbo would blow the heads off. 10 to 12 psi max, and at those boost levels the idi-t will keep up with a stock/mildly tuned 94-97 psd. as or the 460, 6-8 mpg, when a 7.3 is 444 ci and in great shape can get upwards of 15-17, and if it ever goes down quite honestly youd probably come out cheaper from a junkyard getting another idi. they charge for the bbfs, but nobody wants to put a 7.3 into a mustang
93 F250 ext cab 4x4, 7.3 5 speed, Banks Sidewinder, straight piped
(I've actually seen people look up when I pass to find the low flying jet
) 2 tone beige (fugly) I dont worry about how much weight my truck will pull, I worry about how much it'll stop.
jacksonguitars4life is offline
post #4 of 28 (permalink) Old 11-22-2011, 11:44 AM Thread Starter
Thanks for the replies!
During my research on the net, I stumbled onto statements about the IDI's having an issue with thin cylinder walls and pinhole leaks forming, causing eventual catastrophic engine failure. Is this nonsense, or a very real problem that was resolved later on with the PowerStrokes?
I'm still reading and learning, trying to get a fast education so I know weather this truck is worth what he's asking. I think it was a grocery getter, not a workhorse, given it's near new looking interior. My biggest concern is the high mileage and the potential for things to start failing right after I buy it. Is there anything specific I can look/listen for when test driving? I have bought many vehicles over the last 15 years, so I have the general stuff down, but not diesel exclusive points to monitor/inspect.
Comments and advice are truly appreciated.
post #5 of 28 (permalink) Old 11-22-2011, 12:09 PM
Snotzalot's Avatar
My Photos: (5)
I just retired a 1990 E350 with 410,000+ miles on it. The IDI never even had a valve cover off. Other than a few sets of glow plugs a water pump or two it had no other repairs. The motor is still good, wanna buy it?
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is offline
post #6 of 28 (permalink) Old 11-22-2011, 01:25 PM
chuckster57's Avatar
I had an '86 F250 with a 460/C6 that ate corvettes for lunch. I bought it new and over the years, made modifications to try to increase efficiency, and managed to increase HP more than anything. With the trailer in sig, I was seeing 7.7 MPG on the flat highways @70 MPH, it was a GAS HOG!!!
My current truck gets about 10.5 MPG with the same trailer hooked on @ 70 MPH. I wouldn't think of going back to the gas engine for towing.
Having had 9K+ lbs. of trailer hooked on to both a 460 and an IDI ( mind you mine is turbo'd) the 460 will get the load up the hill faster, but it needs a whole lot more fuel to go the same distance. Again remember that My 460 was not stock, but I have pulled that trailer with a stock 460/C6.
The IDI is about the most reliable engine as far as diesels go, and as long as the cooling system is cared for, cavitation is a non worry point in my opinion. repair costs for the IDI beat the PSD hands down. Injectors for the IDI are about $35.00/ea...PSD injectors are about $350.00/ea.
Bottom line: If you can get an IDI for the right price and add a turbo, that's the way to go!!
Train Horns:
PM please not visitor message
chuckster57 is offline
post #7 of 28 (permalink) Old 11-22-2011, 01:42 PM
I can't really tell you how they compare to PS's, but I can tell you how my personal '91 F350 IDI dually with a service body compares to the gas engined service body trucks I regularly drive for a living and to more modern and smaller Japanese cars and trucks.
First off, these aren't really powerful engines, but they're adequate and they pull well. I never have any problem maintaining speeds between 55 and 70 on the freeway and they accelerate well enough that you're not going to slow down traffic. I used to have an International Traveller with a 3.0 Nissan Diesel in it and that was an utter slug in comparison. To me it compares to a full size with a straight six gas engine, but it tows better.
Maintenance wise, they don't really compare to a 2000 era Toyota. I've found lots of little things to fix on mine. On the bright side though, they are EASY to work on. They remind me of pre-emissions control gas engines in that regard. They're simple and you have lots of room to work.
As far as fuel economy goes, I just filled up and I went 178 miles on 13.7 gallons of diesel, making the mpg's almost exactly 13. That's mixed driving and I was hauling stuff on top and inside it for about 1/3 of that. probably 2/3 highway and 1/3 city. That's with a 7.3 IDI, 4x4, E40D, 4:10's, dually rear and a big service body. My best mileage results have been 16 mpg and the worst about 11.5 and I drive like a granny.
My usual work truck in comparison is a C3500 utility truck with a service body and a bucket lift on the back. I'm not sure the exact engine size in it, as it is a company rig, but it is a V-8. One thing I do know however is the kind of gas mileage it gets and that's between 6 and 7 mpg, as I figure it out every time I fill up and thank God for fleet gas cards. I don't recall ever seeing it get more than 7 mpg and it's a 2wd. In fairness however, I do a lot of city driving with it, probably 60%. My old work truck was a gasser F350 bucket truck and while it's been a few years I recall it getting similar mileage to my current company truck.
elmer fudd is offline
post #8 of 28 (permalink) Old 11-22-2011, 01:55 PM
yea the cavitation eating holes in the cylinder walls is preventable with a quality diesel coolant additive. i think we all would recommend the idi engine as a first diesel due to their inherent simplicity and respectable power
post #9 of 28 (permalink) Old 11-22-2011, 02:16 PM Thread Starter
Smile
Thanks guys!
These responses have been most helpful. I've been turning wrenches on gassers for years, so I like the idea of simplicity that you speak of regarding the IDI's. I am convinced that a 460 is out of the question based on my own experiences with my 351W and your mileage reports as well. I know my dad used to complain @ the 8 mpg. so I know that is a bitter pill to swallow.
I am mostly worried about the horror stories I've heard about diesels regarding the expensive injectors and pumps, water/fuel filters and crazy $ oil changes, double batteries and gelling of course in the winter. If all of these "issues" can be mitigated by simplicity of repair, low cost of ownership and better mileage than a gasser...I definitely want to jump on board the gravy train.
Please keep the comments coming. I would love to hear from as many of you current and previous owners of these IDI turbo'd and non-turbo'd engines. Anything I should look at specifically when I go to view/drive this truck. I will be going to look this weekend, and it's a long drive (3 hours each way.) I don't want any surprises or disappointments I could have avoided by being forewarned.
Love this forum!
post #10 of 28 (permalink) Old 11-22-2011, 02:18 PM
Bill1013's Avatar
ShakeFreight2
If you are still considering that IDI, I would ask the seller if he/she kept the SCA's up on it, if he don't know what that means then walk away from it. SCA is "Supplemental Coolant Agent" that is the additive to the coolant to prevent cavitation "thinning of the cylinder walls". A well maintained IDI will go a million miles without too much trouble. Some call the IDI a Powerstroke, a true Powerstroke was not until 94.5 when the engine was computer controlled. Reference: Ford Power Stroke engine - Wikipedia, the free encyclopedia
The IDI's are a good work/towing truck 83-94, the hi torque range is in the low RPM 1600 to 2000, top RPM is governed by the Injector Pump somewhere around 3800. As far as fuel milage goes, 16-18 is very good, some claim 20-21. That F350 with dual wheels will more than likely be 12-16 city.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #11 of 28 (permalink) Old 11-22-2011, 02:31 PM Thread Starter
Oh, I should ad, this is a 4 door, 8 foot bed dually, XLT automatic with every factory option with original 2 tone paint, and 2 wheel drive. Only accessory that seller knows about is an electronic brake booster, which I assume means it has pulled something relatively heavy during its life. It does have the 5k Reese 2" receiver hitch too. I'm hoping it doesn't need a bunch of front end work which I know is very expensive because it's considered a heavy duty/commercial use vehicle. I intend on pulling a 7k pound tandem axle trailer (RV) during the summer, once a week 150 miles roundtrip. Does this truck sound like overkill, or just right?
Edit: Thanks Bill...that's very good info. I will ask seller about SCA. And thanks for clearing that up for me. Again, much thanks folks!
post #12 of 28 (permalink) Old 11-22-2011, 02:35 PM
No such thing as overkill..My mantra " better to have more than enough and NEVER need it, than to NEED it once and not have it"..
Front suspension/steering parts are not expensive, and if you have less than $100.00 worth of tools, you can do everything except the alignment. I did my ball joints in one day and the parts were like $75.00 IIRC.
Train Horns:
post #13 of 28 (permalink) Old 11-22-2011, 02:46 PM
drinkypoo's Avatar
My Photos: (25)
With a good tape measure and ten bucks worth of string, you can probably do the alignment, too. Since there's no caster adjustment it's not exactly rocket science. For me the problem is finding flat ground...
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #14 of 28 (permalink) Old 11-22-2011, 06:49 PM
Well injectors NEW can be had for $26 at the right places, have 8 brand new injectors in mine that cost that much and have no issues with them, they were all BB coded too I think. Injection pumps also aren't that big of a deal, yeah a bit spendy but not too bad. My '90 460 F250 that I had would get about 4mpg on a good day and about 4mpg on a bad day haha, always 4 no matter what I did but the IDI I have (with turbo) would flat out beat that thing in any race any day, the 460 is gutless compared to a well tuned turboed IDI. Dual batteries arent that much of an issue, its just one extra battery you have to buy but its NEEDED, you CAN start them on one battery for emergencies but thats not the best for the truck. They are dirt simple engines, simpler than a carb car since you dont need to fiddle with anything fuel related really, just keep it clean and do regular fluid changes. Like was said before these engines arent horribly powerful, your looking at a stock 7.3NA with 180 horsepower and 360lbft but that bumps up quite nicely with a turbo. These engines were designed by International to run at full throttle redlined for HOURS and not have issues, try that with a powersmoke and you will have a dead engine. In my opinion the IDI is WAY better than any stock 460 around and they can run on almost any sort of fuel oil besides diesel.
'89 F250 SCAB 7.3L ATS Non-Wastegated Turbo
'06 Mazda3 1.6L gutless
'97 Mazda 323 1.3L gutless&nutless
'89F250IDI is offline
post #15 of 28 (permalink) Old 11-22-2011, 08:50 PM
The Rattler's Avatar
I also absolutely LOVE my truck!! Yes it doesn't quite have the get up the new ones do, but I love having a truck that's not computerized!!! The only thing I see different than everyone else is milage. I get 8 mpg while towing 11K worth of 5th wheel and 10 when unloaded. Granted I do have the pump turned up just a bit... Before that I sometimes got 12 unloaded, but never ever in 10 years have I ever got over 12 and I only have 64K on it
1994, F-350, 7.3 IDI Factory Turbo, 67K miles (8-2012), super cab, Dually, long box, 155WB, 4.10 rear, E4OD Tranny #2 replaced @ 33K with small cooler(New torque converter in June of 09, K&N filter, ride rite boots, Pyro and Tranny temp sensors everything else is stock!
The Rattler is offline
