not idi but ?for diesel gurus - Diesel Forum - TheDieselStop.com
Old 03-05-2005, 12:32 PM   #1 (permalink)
[img]/ubbthreads/images/graemlins/shrug.gif[/img]i have a76f250 project truck and afriend has i believe he said 3208 cat he said i could have it runs. will this engine have enough power to tow 32 5er? and will it run on biodiesel? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
94 f250 7.3 turbo diesel 5spd 4x4 (only mod luk s
mf)
1976 f 250 s/c 2wd (project truck)
commonsthor is offline
Old 03-05-2005, 02:51 PM   #2 (permalink)
hesutton's Avatar
My Photos: (30)
Re: not idi but ?for diesel gurus
I've got good news for ya. There is a member by the name of Dave Haven who has a 3208 Cat in a 1970 F350.
Here is a post a month or so ago reguarding the 3208... HERE .
Here are his photos of the beast... HERE. Click on the "trick truck" images.
PM him with any questions. I'm sure he'd be glad to answer them.
Heath.
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
hesutton is offline
Old 03-05-2005, 05:11 PM   #3 (permalink)
went to buddies salvage yard today to what other diesel engines he had. he has 6 cylinder perkins with turbo on a big generator i think.has anyone ever played with one of these. i got it fired up and she runs pretty good, i would have to figure out trans to use [img]/ubbthreads/images/graemlins/shrug.gif[/img]what size engine is in small dozer? i would prefer inline diesel as i belive it would fit better
Old 03-05-2005, 08:53 PM   #4 (permalink)
how many liters is the 3208?
92 F250,7.3,E4OD,BANKS POWER,COOLANT FILTER,8 FOOT WESTERN PRO PLOW 193,000 on original ip and injectors
rancherman84 is offline
Old 03-05-2005, 11:16 PM   #5 (permalink)
Dave Haven's Avatar
My Photos: (16)
[/ QUOTE ]10.4 liters. 636 cubic inches.
"Big Red"-'89 F-250 4X4 reg cab; 7.3; Cat ELC (no problems, ain't skeered ; 4.10 axles; 5-speed ZF "Bolt-Action"; ATS turbo installed @ 158K; Holley "Red" pump; new injectors and 2nd Reman IP@ 234.5K; "Coffee Can" (4") downpipe-back exhaust....
6220#
"Trick Truck"- 1970 F-350 w/custom utility bed and cabover camper; Cadillac leather seat; CAT 3208 w/turbo from CAT 613 scraper; 5" straight pipe; 6-speed Allison "slush box"; 3-speed "Brownie"; 2-speed Eaton rear axle from F-600; Custom rear deck w/ air compressor, Lincoln arc welder, Oxy-Acetylene rig, and boom crane....
17,940# 26' Class C motorhome
"White Pony"- 2007 Mustang; 4 liter V6; "5-shot bolt action" (an automatic in a Mustang is just WRONG!)
Dave Haven is offline
Old 03-05-2005, 11:25 PM   #6 (permalink)
My Photos: (23)
You would think with all those cubes, that it would make more HP than the 170 or so that it does. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, Moose Mister Injectors, Hypermax Turbo, Intercooler, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 03-06-2005, 01:00 AM   #7 (permalink)
Guest
Posts: n/a
...but don't it make something like 800 ft-lbs trq????????
Old 03-06-2005, 02:08 AM   #8 (permalink)
You get bigger in size you get more torque, but the horsepower doesn't climb as fast. My N14 is 14 liters (about 850 cubes) but it only has 500 horse. Now torque on the other hand is 1650 ft lbs, and I could turn it up to 1850 (tranny's only rated for 1650...sigh...).
My pics...
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
Old 03-06-2005, 08:45 PM   #9 (permalink)
hesutton's Avatar
My Photos: (30)
Well I found a post about an engine swap with a 6.0 Perkins into a '70's Ford truck. Here's the post.
Here is a link to the pictures of the truck... HERE.
Heath
hesutton is offline
Old 03-07-2005, 03:44 PM   #10 (permalink)
Dave Haven's Avatar
My Photos: (16)
[/ QUOTE ]NA engines were rated at 175, 200, or 210 HP. Turbocharged truck engines were rated 210 or 250 HP.
Turbocharged, aftercooled marine engines were rated up to 435 HP.
Old 03-08-2005, 09:07 AM   #11 (permalink)
[img]/ubbthreads/images/graemlins/confused.gif[/img]ok so the perkins will work ,there is not a trans as i belive this was on a big generator originally. so have to figure out trans for it . my buddy said he is going to heavy equipment auction at end of month if i want him to look for another type of motor?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]what type of equipment would a cat c7 be in ?? i played with the perkins on sun she really sounded good it has hour meter but it is broke,with no muffler it is pretty loud tried to figure out how to mount trans ,just need to make some kind of adapter would to find some type of auto that would work [img]/ubbthreads/images/graemlins/smokin.gif[/img]would like to be able to smoke a cummins with what ever i put in this truck as a guy in town is always kicking my idis *ss
mf)
