ive seen a few pics on here with a plastic one mine is metal and barely holds on
which is stock?
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
There were 2 styles.... the old 6.9 has a radiator cap style mounted on a tube from the inspection cover area where the IP bolts are..... The 7.3 has a plastic cap that threads into the oil filler tube which is a moulded part of the timing gear cover...
ya thats the one i thought of was correct but my fill tube is straight up (possible newer style or a replacement part)
Hate to say it but are you sure you have a 7.3? all the 6.9's had the fill tube straight up and down. All the 7.3's had it off the ip tower.
Take a picture of yours? Could be an international thing since you got it out of an international truck. If its the metal kind that has little tabs...i dont have any that will work for that. I have the plastic threaded one. The metal filler tube on the 6.9's was a push down and turn deal.
well i think it was interchanged then
i am sure its a 7.3 tag decodes that way and im but i found out it was not converted like the previous owner told me it was ill look at some of the 6.9 guys pics but i know its probaly not the right part now that would explain the constant leaking of oil around the seal and how its a bit small
Post the serial numbers on the top of the block next to the drivers side head right up front. Then I can tell you if the motor is a 6.9 or 7.3. Maybe even what year it is.
ok ill look when i go out later any other ways to tell ?
That number, by the head and to the drivers side of the IP, either beging with "U6.9......" or"U7.3........".
6.9=6.9
7.3=7.3...DUH
1985 F-350 6.9 IDI w/101k miles, RC, 4x2, DRW, 4.10 gears, ZF-5speed, 5" stack, manual glow plugs, flatbed, buckets and center console off a bronco and no soup bowl!
Pics.: My Truck
Up next: Turbo, full instrumentation, hydroboost brakes
ok kool never thought to check the numbers kinda expected normal serials with no way to decode without a decoder
