Re: Oil change
Sitting is the worst thing, moisture builds up in the oil from condensation. It depends how often the truck is driven, if you run it every few weeks enough that the motor gets good and hot (I'm talking highway hot, not idling hot) then you can extend the oil change out since the water has a chance to boil out of the oil.
*ASE Master Certified, Medium & Heavy Trucks*
