oil cooler - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 09-07-2011, 01:27 PM Thread Starter
oil cooler
does anyone know where to get an oem oil cooler? i tried ford and international and they both discontinued it
travislalli is offline
post #2 of 13 (permalink) Old 09-11-2011, 09:58 PM Thread Starter
anyone have any ideas?
post #3 of 13 (permalink) Old 09-11-2011, 10:13 PM
PabstBlueRibbon's Avatar
Send a message via AIM to PabstBlueRibbon Send a message via Skype™ to PabstBlueRibbon
knowing what truck you have would help
1993 F350 7.3 IDI S/C L/B SWR W.B. 133
PabstBlueRibbon is offline
post #4 of 13 (permalink) Old 09-11-2011, 10:27 PM
chuckster57's Avatar
LMC? On my iPhone right now so I can't look it up
Train Horns:
PM please not visitor message
chuckster57 is offline
post #5 of 13 (permalink) Old 09-12-2011, 12:21 AM
Bill1013's Avatar
Ya gotta put your truck or van in your sig. All 6.9 and 7.3 oil coolers are not the same per se, the truck is different from the van.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #6 of 13 (permalink) Old 09-12-2011, 09:23 AM Thread Starter
oo ok its an 89 f350 7.3 with a 5 speed conversion
post #7 of 13 (permalink) Old 09-12-2011, 11:32 AM
drinkypoo's Avatar
My Photos: (25)
you can pull one from any 7.3 f-series.
are you sure you need a new one? there's a seal replacement procedure.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #8 of 13 (permalink) Old 09-12-2011, 11:46 PM Thread Starter
yea i need a new one mine rotten out in the middle and its makin a mess. i dont really want to put a used in id rather buy new but i cant find them
post #9 of 13 (permalink) Old 09-13-2011, 02:22 AM
siegler's Avatar
What part do you need (end caps or center part). You should be able to get a center from navistar, but the end caps would have to come from a wreck/ebay/Craigslist. If you are near Seattle I have a good center and front end cap, and access to a whole unit from an 87 6.9 that is being scrapped.
1990 F-250 XLT Lariat 4x4, reg cab, 7.3IDI N/A, T19C (swapped in place of E4OD 11/10), dana 60 front, rear grizzly locker 4.10 gears, 35" mud tires, 5" lift
siegler is offline
post #10 of 13 (permalink) Old 09-13-2011, 05:23 AM
drinkypoo's Avatar
My Photos: (25)
If you can find it, it will be very spendy.
All cars run on used parts.
post #11 of 13 (permalink) Old 09-13-2011, 11:07 AM
Bill1013's Avatar
Here is pics of an oil cooler. What part do you need? Never heard of one rotting out.
Bill1013 is offline
post #12 of 13 (permalink) Old 09-14-2011, 01:11 AM Thread Starter
i d the center part the trucks primary use is snow removal i tried my local international dealer they claim they cant get it
post #13 of 13 (permalink) Old 09-14-2011, 06:55 AM
drinkypoo's Avatar
My Photos: (25)
It is not unheard of for the tube portion to corrode out, but more likely is for it to be clogged. Regardless, you should be able to pull the center tube from any 7.3 cooler, E- or F-series. E-series may be easier to pull (!)
