Welcome to the Diesel Stop
To BOTH of you guys.
The valve cover gaskets can wear and leak over time. The bolts that hold them in place can become loose and the "spreaders" will not hold the cover down tight. They are cheap enough and easy to replace. Just pay attention to the way (top) the spreaders go back on. Since yours is NOT turbo'd it is easy to get to all the bolts
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
